September 17, 2026, 03:28:56 am
Hoffman Amps Forum image Author Topic: Any reason why I couldn't use this MOSFET for an FX Loop buffer? (STP5NK80Z)  (Read 7135 times)
Offline SnickSound
Went to the local surplus store to pick some parts for my experiments, the only high voltage MOSFET they had was this thing: https://www.mouser.ca/ProductDetail/?qs=mllD5Vm88X%2fZuILlW1Jbew%3d%3d
Quickly looked up the specs online, saw 800V and 4.3A and figured better go over than under and bought it.
Then I came home and took the time to look at the complete datasheet, noticed the fairly high input capacitance (over 900pF!), but I also remembered RG's words about input capacitance being less of an issue when used as a "cathode follower" so I went ahead and breadboarded it... and it works! There's no perceptible loss of high-end and it drives long cable runs and low impedance loads like a champ.
I like the big thick leads which will make it easier to use on a turret board, it's internally zenered which means one less thing to worry about (it does have a low 10V max Vgs, but I don't believe that's much of an issue for this use case). I do notice the much slower rise and fall times though (more than an order of magnitude slower than an LND150)
So anyway, since I have it already and it seems to work fine, any reason why I should not use it? Don't feel like paying 20$ shipping to get something else from Mouser if it's not necessary (I'm in Canada).
And suppose I was to not use it, what else can I use such a MOSFET for. VVR?
Offline 2deaf
  • Now too deaf for 100 watts
The reverse transfer capacitance is the one involved with the Miller effect, but the gain of a source follower is less than 1 making the Miller effect a non-issue.  The massive NFB of a source follower is going to give you an excellent frequency response.
If you have the TO-220FP package, those are really cool because you don't need that insulating pad and some kind of bolt insulation.
That MOSFET will work fine as a source-follower FX send, as you already found out.  It will also work fine for anything you would use an IRF820 for.
Sorry.
« Last Edit: January 14, 2019, 05:35:40 pm by 2deaf »
« Last Edit: January 14, 2019, 06:04:16 pm by sluckey »
As cathode follower, this is bootstrapped out. We can't know the exact gain of this beast at your hyper-low current, but "30" is conservative, meaning 29/30 or 0.97. In short, 910pFd Ciss becomes 30pFd, plus the 20pFd Crss, makes 50pFd. A 12AX7 gain stage is 100pFd, there's 30+pFd at any node of a guitar amp, 50pFd is very typical tube amp internal capacitance, you don't have a problem.
Offline 2deaf
I just looked at the ST datasheet and it actually shows a max Vgs of 30V.  I also noticed that the Ptot for the TO-220FP is only 30W, but that is still way overkill.  For the input capacitance of a source follower:   Cin = Crss + (Ciss - Crss)(1 - A)
Offline SnickSound
Thanks everyone for the help! As I said, it works on the bench, but better make sure.
While we're on the subject, is it correct to say that I should use a coupling cap rated at least as high as my power supply voltage?
