September 17, 2026, 02:11:07 am
Hoffman Amps Forum image Author Topic: Power up without reverb tank  (Read 6351 times)
Offline Papa Jim
« on: January 14, 2019, 04:06:19 pm »
I would like to power up a Twin Reverb Amp without a reverb tank present. The output on the amp has a 12A shorting plug that shorts in the output to the reverb tank if it is not present. Is this too risky to do. If so I can wait until tomorrow when I can get my hands on a cable for connecting the tank
Re: Power up without reverb tank
« Reply #1 on: January 14, 2019, 04:12:56 pm »
I fire up Fender amps without the reverb tank all the time..  no harm done so far. What Twin do you have ?  A reissue?  Must be if there is a switchcraft 12A jack on it..
Guess you could always pull the 12AT7 driver if you are concerned..
« Last Edit: January 14, 2019, 04:32:13 pm by mresistor »
Offline Papa Jim
« Reply #2 on: January 14, 2019, 04:55:26 pm »
Yeah Reissue.  I just found some cable and hardwired it up to the tank by soldering to the back side of the RCA Jack inside the tank just to be safe. Thanks
« Reply #3 on: January 14, 2019, 05:12:19 pm »
I'm looking at the schematic of the twin reissue and I don't see any switchcraft 12a that goes to the reverb tank. The reverb tank is connected with rca jacks.   I think the 12A jack you are describing is the footswitch jack.  Seriously.  there is no harm turning on a Fender amp with the reverb tank disconnected..   you didn't have to solder to anything..
« Reply #4 on: January 14, 2019, 05:14:00 pm »
If you really have to have to reverb tank connected, like to trouble shoot the reverb circuit, then you need two double female ended rca adapters and some stereo rca cables.. like what you would use to hook up a stereo amplifier to a cd player
« Reply #5 on: January 14, 2019, 05:17:09 pm »
Hmm. My TR Reissue has a funky looking dual RCA jack for the reverb tank. The jack is located on the top of the chassis rather than the back of the chassis like the old '60s Fender amps.
« Reply #6 on: January 14, 2019, 05:20:41 pm »
Are you sure this amp has a 12A shorting jack in the reverb circuit ?  Looks like a Switchraft 11 to me on the footswitch.
http://ampwares.com/schematics/65_twin_reverb_@20manual.pdf   Mods  is this in the library?
« Last Edit: January 14, 2019, 05:31:27 pm by mresistor »
« Reply #7 on: January 14, 2019, 06:01:38 pm »
The footswitch jack is a 1/4" stereo phone jack, similar to Switchcraft 12B stereo jack.
Offline Papa Jim
« Reply #8 on: January 14, 2019, 09:25:59 pm »
Somebody modified it to have a 12a the tank that I can't get my hands on tonight has a cable with rca at one end for the tank and  1/4 phono plug at the other end.  I got it powered on and no problems. Sorry I've been working and did not get back to post. All is fine. Thanks guys you are great help whenever I need it.
