September 17, 2026, 04:22:55 am
Hoffman Amps Forum image Author Topic: Wiring in a Power Transformer  (Read 5323 times)
Offline newguitarsmell
« on: January 17, 2019, 12:44:34 am »
Hi
I recently needed a vertical style PT so I got this one
http://www.classictone.net/40-18085.pdf
For a 5f2a build.
I have never used a PT with so many wires.
Which two do I use? I am thinking Black and Brown and White --
But do I need to tie in the Black and white and Brown somehow?
Please help!  :BangHead: :BangHead: and THaNKs!!
« Last Edit: January 17, 2019, 12:47:01 am by newguitarsmell »
Re: Wiring in a Power Transformer
« Reply #1 on: January 17, 2019, 12:57:47 am »
what country do you live in? specifically, what's the line voltage were you'll be using the amp?
« Reply #2 on: January 17, 2019, 01:16:23 am »
if you're using a NOS 5Y3GT rectifier, use the two red wires and tie them each to pins 4 & 6 of the rectifier socket then TAPE off both red/white wires INDIVIDUALLY - we don't need them. the red/yellow goes to ground.
if you're using a "russian/chinese/bohemian" or new production 5Y3 or a GZ34/5AR4, use the red/white wires and tie them each to pins 4 and 6 of the rectifier socket then tape both red wires off INDIVIDUALLY - we don't need these. the red/yellow goes to ground.
for 120V:
1) tie the black and brown together - this is the "neutral" lead.
2) tie the black/white and the brown/white together - this is the "hot" lead.
« Reply #3 on: January 17, 2019, 08:33:11 am »
Page two of that pdf clearly shows how to wire the primary.
