September 17, 2026, 03:12:36 pm
Hoffman Amps Forum image Author Topic: GA15 RV turret board  (Read 6538 times)
Offline mak009
« on: January 21, 2019, 06:22:12 pm »
Hi,
First post :icon_biggrin:
Any thoughts on how to build up a turret board for a Gibson (Trace Elliot designed and built) GA15RV? I have the schematic and component list (from the manual)
The amp sounds great but is constructed "to a price" with fairly skimpy PCB traces and machine stuffed with 1/4 watt resistors and low grade components.
I am planning on building a more robust version on a turret board.
Any help much appreciated
mak009
Australia
Re: GA15 RV turret board
« Reply #1 on: January 21, 2019, 06:58:26 pm »
Read the first two topics in the "Hoffman Turret and Eyelet Boards" forum.
Offline mak009
« Reply #2 on: January 21, 2019, 07:33:38 pm »
Thanks for the reply.
I had already read those posts, but there is no info on how to transfer a schematic to a .dxf file.
That seems to be the tricky part-do you have to do this manually or is there a prog which accepts scanned schematics and generates a layout for turret or eyelet boards? Obviously there are lots of decisions in there regarding grounding scheme, power supply topology etc.
« Reply #3 on: January 21, 2019, 07:55:31 pm »
Open the very first topic and look at the second line in the first post. Click on the link to go to Doug's program to create a custom board. Now click the button that says "Click here to create a new Board file". Follow the instructions to start putting turrets on a blank board.
« Reply #4 on: January 22, 2019, 09:52:53 am »
I think you're looking to submit a schematic, and have it automatically turned into a layout? if so, not on this site. You create the layout yourself on graph paper or whatever, and then manually input the info where Sluckey said.
Offline mak009
« Reply #5 on: January 22, 2019, 07:45:35 pm »
OK Thanks. Back to the drawing board.
