September 17, 2026, 04:14:10 pm
Hoffman Amps Forum image Author Topic: MOV or capacitor in Egnater rectifier section  (Read 7711 times)
Offline mechtonia
« on: January 23, 2019, 02:26:15 pm »
My Egnater Tweaker 40 started blowing fuses and in the process of tracing the circuit, I came across a what I think is a capacitor across the input of the rectifier. Is this indeed a capacitor and if so what is it's purpose? Filtering? I have limited experience but I haven't seen a capacitor across the input of a rectifier.
Schematic of rectifier section of circuit:
Image of rectifier components:
Also, can anyone with Egnater experience confirm if this is stock/typical? This is on the bottom of the power board opposite a relay.
Re: MOV or capacitor in Egnater rectifier section
« Reply #1 on: January 23, 2019, 02:36:56 pm »
Welcome.
What is the component designator under the blue lump? (Like C41, D9, R69...)
In general, either a cap or a MOV here would be a just-in-case protection against different crap coming from the power line. (I do have doubt about how they implemented it.)
The other mod might be a poor factory change or a later owner's hack-work.
Offline mechtonia
« Reply #2 on: January 23, 2019, 02:52:59 pm »
The component designation is C46. All other capacitors have a"Cxx" designation too.
« Reply #3 on: January 23, 2019, 02:58:35 pm »
Pull the handy HV fuses. Feed a 9V battery through a 1K resistor, each side one at a time, see if you get 7.8V (9V - two diode drops) at the other end, and if the 9V leaks from one side to the other
Offline mechtonia
« Reply #4 on: January 28, 2019, 08:54:21 am »
Winner winner chicken dinner.
I performed the test as described and it failed. So I replaced the cap and everything looks good on the power front. Except the amp has no output. I made a new thread about it here https://el34world.com/Forum/index.php?topic=24246.0.
« Reply #5 on: February 02, 2019, 10:45:22 am »
Yes - the capacitors help filter out any possible rectifier switching noise that can be created. There's other things like transformer ringing and/or oscillation prevention as well.
