September 18, 2026, 07:49:48 am
Hoffman Amps Forum image Author Topic: Small transformer for space rack, with heater tap and 12v secondary.  (Read 4378 times)
Offline Captain chunkulus
Any of you guys know of a good transformer that the will fit a space rack chassis with a heater tap and a 12v secondary? Thanks.
Offline 1blueheron
Re: Small transformer for space rack, with heater tap and 12v secondary.
« Reply #1 on: January 24, 2019, 10:06:45 am »
By "space rack" I am assuming you mean single U rack space for 19"rack mount??
You might want to take a look at toroidal style transformers.  Typically they would have a lower profile than an E&I style.
Something like this maybe?  https://www.toroidal-transformer.com/shop/high-end-audio/power-transformers/730/3n1904--xn1904--voedingstrafo-voor-buizenversterkers-71va.html
Do you just need 6.3V and 12V.  No HT?
« Reply #2 on: January 24, 2019, 10:28:26 am »
2 space rack sorry. I need a primary for power and 2 secondaries. Both could be 6.3 volts. One for heaters and one for relays.
Offline 1blueheron
« Reply #3 on: January 24, 2019, 11:35:55 am »
Could you use dual primary dual secondary and just feed both primaries from the same AC power source?
These look like they fit your requirements.
https://www.mouser.com/datasheet/2/177/266-948812.pdf
Offline dunner84
« Reply #4 on: January 24, 2019, 01:28:55 pm »
2 Hammond 229 series transformers
