October 04, 2026, 11:49:37 pm
Hoffman Amps Forum image Author Topic: Resistor designation  (Read 28387 times)
Offline Swampertech
« on: January 25, 2019, 09:08:45 am »
When I try to assign a value to a resistor (ohm, K, or M) in the dropdown page, the ohm character has been replaced by a capitol I with a tilde above and also a copyright character.
Re: Resistor designation
« Reply #1 on: January 25, 2019, 09:13:40 am »
yeah me too
I will report it
Bancika was having trouble making the ohm character work
looks like something got broke
Offline Swampertech
« Reply #2 on: January 25, 2019, 09:16:38 am »
Doug, mine worked about a week ago. Also, thanks for creating this program.
« Reply #3 on: January 25, 2019, 09:36:03 am »
It's version 50.0 only, the new version
I did not create the program, Bancika did
« Reply #4 on: January 25, 2019, 10:59:17 am »
Another bug in 50.0
Resistors, diodes and jumpers seem to be affected by color changes if you change the angle
If you open the edit selection menu, you can change the Red leads back to the original color.
FF0000 is the color that the leads were changed to
CCCCCC is the original lead colors that I use
Offline Swampertech
« Reply #5 on: January 25, 2019, 11:59:40 am »
I noticed that too last night. Can I make a request of Bancika to make a jumper, or wire option where they can be striped, like the 50V bias winding wire? And tell Bancika thanks so much for this great program. There's something else too. When I open a folder on the left of the page (building blocks, recently used, etc.) it looks like the items in the folder double or triple and are impossible to read until I close the folder and reopen it. Again, thanks Bancika for the hard work.
« Reply #6 on: January 25, 2019, 12:12:24 pm »
Feature request and issues are posted on GITHUB here.
https://github.com/bancika/diy-layout-creator/issues
Sounds like a MAc issue with that menu?
There is another post here in this board about MAC issues and some links
