September 17, 2026, 10:40:23 pm
Hoffman Amps Forum image Author Topic: hookup for switch  (Read 5149 times)
Offline davidwpack
    • My music on reverbnation
hookup for switch
« on: January 29, 2019, 12:12:01 pm »
Hey. I just received a small lot of 3-lug illuminated switches that I wanted to try to use.Can someone confirm that the attached photo is correct? I thought when I purchased them that a lug would be dedicated for 6.3 volts for the bulb but apparently it operates off of the full voltage? Ratings are: 250VAC @ 16A or 120VAC @ 20A. Secondly, given those ratings, is using this also for a standby switch not viable? I have no DC ratings for it. I'm expecting around 420VDC. Would it fry? Thanksssssssssssssss!
Online sluckey
Re: hookup for switch
« Reply #1 on: January 29, 2019, 01:08:19 pm »
I like using those switches for power switches. Makes for a really neat, simple mains wiring. DON'T CONNECT THE LAMP CONTACT TO GROUND. It connects to AC Neutral. Like this...
     http://sluckeyamps.com/supro/supro.pdf
You can probably use the same switch for a standby switch. Sunn did, but their switches look a bit heftier than that. Give it a try, but don't connect the lamp directly to ground. Use a 220K or 330K or 470K between the switch lug and ground.
Offline davidwpack
« Reply #2 on: January 29, 2019, 01:22:21 pm »
Thank you muchly Sluckey! I remembered you used switches similar to that but for some reason I was thinking that yours weren't illuminated. I should have opened your schematic. Thanks!
Online sluckey
« Reply #3 on: January 29, 2019, 01:26:47 pm »
Be sure you know which switch lug is which. The numbers on my switches are different from your numbers. Very easy to sort out the actual switch contacts with an ohm meter. And the lamp contact will have no continuity to the other contacts.
Offline davidwpack
« Reply #4 on: January 29, 2019, 01:55:50 pm »
Ok. I'll remember to confirm that before wiring it. Thanks!
