September 17, 2026, 04:13:53 pm
Hoffman Amps Forum image Author Topic: Impedance question  (Read 4614 times)
Offline Leevi
    • Rikstone
Impedance question
« on: January 31, 2019, 08:59:24 am »
The amp is a Vox AC15 based with 2xEL84 power tubes 8 and 16 Ohm output.
Is it ok to plug two 8 Ohm speakers to it i.e. one to 8 Ohm output and one to 16 Ohm output.
I know that it will work but will it change the load impedance (~5K) radically?
/Leevi
Re: Impedance question
« Reply #1 on: January 31, 2019, 09:50:41 am »
I would not do that. I don't even know how to calculate the load impedance. I would just connect the cabs in series and plug into the 16Ω jack. Look at page 14 of this pdf to see a simple cable that will do this...
     http://sluckeyamps.com/misc/Amp_Scrapbook.pdf
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #2 on: January 31, 2019, 11:48:17 am »
I believe that would be the same as plugging 2.67 Ohms into the 8 Ohm tap alone.
Offline Leevi
    • Rikstone
« Reply #3 on: January 31, 2019, 12:38:56 pm »
Thanks for the document Sluckey. There was a 4 Ohm tap in the OT so
I solved the issue by using a switch.
Leevi
