September 18, 2026, 07:55:09 pm
Hoffman Amps Forum image Author Topic: Can you switch between output transformer taps with a speaker jack?  (Read 9701 times)
Offline dbishopbliss
    • Bliss Amplifiers
The output transformer of the Silvertone 1482 I am restoring has a 4 ohm and 8 ohm tap.
I would like to add an external speaker jack that would run the internal and external speakers in parallel off the 4 ohm tap, but run the internal speaker off the 8 ohm tap when the external speaker is not connected. Is it possible to do this with just one jack? I have and amp that disables the internal speaker when I plug an cable in to the external speaker jack but I can't think of how to make both speakers run in parallel AND switch between the leads.
If not, I can always cheat and simply add 3 speaker jacks. One for 8 ohm and two connected in parallel for 4 ohm. Just trying to be clever.
Check out my blog for more details. Bliss Amplifiers
Offline Papa Jim
Re: Can you switch between output transformer taps with a speaker jack?
« Reply #1 on: January 31, 2019, 04:50:50 pm »
There are lots of jacks available with normally closed, or normally open switches. You can simply connect the sleeve of the jack to the - of the internal speaker, and the  tip of the jack to the + of the internal speaker. Then use the proper switch on the jack you select to do nothing but break the 8 ohm tap to the internal and connect the 4 ohm tap to it when the plug is installed while the speakers are in parallel.
Or one jack wired to the internal speaker with a separate single throw double throw switch that switches which tap goes to the tip. If it is switched wrong no danger I don't believe if a 4 ohm tap inadvertently gets connected to your internal 8 ohm speaker. If so others please chime in.
« Last Edit: January 31, 2019, 04:57:54 pm by Papa Jim »
« Reply #2 on: January 31, 2019, 05:16:41 pm »
Checkout the schematic of the Fender Hot Rod Deluxe.  It does exactly what you want.
    • Bliss Amplifiers
« Reply #3 on: August 21, 2019, 08:08:06 am »
I moved, got a new job, death in the family, kids went to college, etc. Its been a busy 6 months but I'm finally going to wire this thing up so I'm resurrecting this thread.
Attached is the schematic for the FHRD. I'm confused by the connections. It looks like one jack has 4 connectors and one has 3. Can someone help me identify the parts I will need to buy to implement this?
    • Bliss Amplifiers
« Reply #4 on: August 21, 2019, 08:20:35 am »
I think I found them here. Parts J-12A and J-13A. Now I just need to decipher which connection goes where.
    • Bliss Amplifiers
« Reply #5 on: August 21, 2019, 09:44:05 am »
Anyone know what the wire labeled Gray in the diagram above is? NFB Loop maybe? I don't think the 1482 has any NFB.
« Reply #6 on: August 21, 2019, 09:54:30 am »
Yes, NFB loop.
    • Bliss Amplifiers
« Reply #7 on: August 21, 2019, 08:07:15 pm »
Now that I have the jacks on their way... where do I mount them? There isn't really much room on the back panel and the space that is available has the model number, etc that I would like to keep.
There is some space on the top/side (whatever you call it) near the power tubes. This would allow me to plug in the speaker more easily... I may have to re-route some wires on the inside of the chassis, but there isn't much going on there. Should I be worried about introducing hum?
Another thought I had was making a "chassis extension." Basically a small sheet of metal that I would drill holes into... one for each jack and then another that I would use to hold on the extension by threading the Footswitch jack through and securing with the nut. Maybe I can use two holes for the footswitch and the pilot light so it will be a little more reinforced. The problem with this plan (if it is a problem) is the output transformer wires would be on the outside of the chassis running past the power tubes.
Your advice and suggestions are welcomed and encouraged.
Offline Tony Bones
  • Thread Killer
« Reply #8 on: August 21, 2019, 09:03:58 pm »
Would they fit around the corner from the model number? On the same surface that the tubes and transformers are mounted.
Offline dude
« Reply #9 on: August 21, 2019, 10:35:09 pm »
Your idea of hanging a piece of metal  off the foot jack seems like a good method, won’t butcher the amp and easy to do. Use a piece of metal thick enough to support the two shorting spk jacks. That schematic would give you one 8 ohm spk on main jack on 8 ohm tap and when using another 8 ohm spk the 4 ohm tap would be used.
« Reply #10 on: August 22, 2019, 01:55:43 am »
The pictured amp looks to be in dire need of a safety ground for its chassis
    • Bliss Amplifiers
« Reply #11 on: August 22, 2019, 08:14:01 am »
That's a before picture. I have since upgraded to a grounded cord.
    • Bliss Amplifiers
« Reply #12 on: August 22, 2019, 08:26:22 am »
Another challenge with the "outrigger" that I have found is there is not a lot of thread left on the footswitch jack. So, using a thicker piece of metal will not allow me to screw on the nut. I could get a longer threaded jack.
Another thought I'm having... what if I mounted a jack plate on the rear panel (I'm making a custom cabinet anyway). It might be weird to have the combo speaker wire run to the outside to plug in and it would make working on the amp more challenging... but it might work.
    • Bliss Amplifiers
« Reply #13 on: August 22, 2019, 03:23:46 pm »
I just thought of a simpler solution (I think it should work). Rather than having two jacks, I will only have the Switchcraft 13A (Tip/Sleeve with transfer switching) jack installed into the back panel of the cabinet. Then I will make the following connections:
  • Internal Speaker + to Tip tab of the Jack
  • Internal Speaker - to Sleeve/Ground tab of the jack
  • 8 Ohm OT connection to the Shunt tab of the jack.
  • 4 Ohm OT connection to the Open Shunt tab of the jack.
  • Ground of the OT connection to the Sleeve/Ground tab of the jack.
This way, when no external speaker is plugged in the 8 Ohm connection will go to the internal speaker. When I plug in an external speaker, the open shunt connection will be made and the shunt connection will be broken thereby connecting both speakers in parallel to the 4 Ohm tap.
The only drawback (which I don't think is an issue) is the internal speaker will always be connected. I don't really plan on running this amp as a "head" and only wanted to have an extension speaker to add a little variety.
Please let me know if there are any issues with doing this.
I will run the 8 ohm OT wire to the Shunt tab
« Reply #14 on: August 22, 2019, 03:46:02 pm »
•Internal Speaker + to Tip tab of the Jack
don't see a problem except the "normal" problem with any head unit, IF the tip
sticks open with no speaker plugged in.  low probability chance anyway
