September 17, 2026, 09:46:05 am
Hoffman Amps Forum image Author Topic: Hoffman AB763 SR tremolo thump  (Read 5129 times)
« on: February 04, 2019, 02:35:38 pm »
I have a Hoffman AB763 board in my Super Reverb..    I have the red led mod installed, and 150K resistor instead of 470K and replaced one of the .1uf caps with a .047uf I think its C31 - it's the one closer to the led.
The trem is much stronger now, before it was weak.  But after about 3 1/2 - 4 on the intensity dial I am getting some fairly audible thumping.
Would the diode across the intensity pot reduce this thumping? Any other ways to reduce it?
It's biased around 65%.
« Last Edit: February 04, 2019, 02:40:01 pm by mresistor »
Re: Hoffman AB763 SR tremolo thump
« Reply #1 on: February 04, 2019, 02:59:29 pm »
The diode across the INT pot is supposed to address the thumping.
Offline Joel
« Reply #2 on: February 05, 2019, 04:33:17 am »
I had exactly this problem.
The diode across the Intensity pot did not help.
I found my solution here: http://el34world.com/Forum/index.php?topic=23529.msg253086#msg253086
Essentially, lower the Trem oscillator voltage to 300V.  It's a little bit weaker, but there is no tick/thump.
The mouth of a happy man is filled with beer  - Egyptian Proverb
« Reply #3 on: February 05, 2019, 09:03:21 am »
Thanks guys..     I put a brand new JJ 803S in the trem and that helped but still some audible thumping. I jumpered in the diode across the int pot and the trem is now very quiet, deep and lush.
So I can say the diode mod worked in my case. My V5 plates are 425v.
Joel - how did you go about lowering the plate voltage to V5?
« Last Edit: February 05, 2019, 09:06:14 am by mresistor »
