September 15, 2026, 03:52:10 am
Hoffman Amps Forum image Author Topic: V1 A and V1 B?  (Read 6149 times)
Offline Rockranger
V1 A and V1 B?
« on: February 06, 2019, 04:35:30 pm »
Hey guys I have a number of homemade 15 to 20 watt amps which I love, I play them with a 12ax7 in V1 when I play with other people and when I’m at home I play them with NOS 12 au7 or 12 at7 in V1 ( this is my favourite way to drop the volume and still have the amp sound great) , a friend really likes the way this sounds and wants me to build one for him (Hoffman 6v6 plexi), I was just wondering if there was an easy way to have 2 V1’s like mabey one input jack go through V1 A and another input jack through V1 B, instead of him taking tubes in and out of the amp? Any thoughts or suggestions would be greatly appreciated!
https://el34world.com/Hoffman/files/Hoffman_Plexi_6V6-V2.pdf
Re: V1 A and V1 B?
« Reply #1 on: February 06, 2019, 04:45:01 pm »
Very easy. Just use a 12DW7. One triode is like a 12AX7. The other triode is like a 12AU7. Use a separate input jack for each triode.
Offline Rockranger
Re: V1 A and V1 B?
« Reply #2 on: February 06, 2019, 05:00:23 pm »
Wow never heard of a 12dw7, that sounds easy enough, thanks sluckey! So other than a separate jack for each triode the rest of the V1 connections to the board stay the same?
« Last Edit: February 06, 2019, 05:18:14 pm by Rockranger »
Re: V1 A and V1 B?
« Reply #3 on: February 06, 2019, 05:43:16 pm »
Yep. It's that easy. Shop around. The JJ 12DW7 is much more affordable than other brands. I have some JJs and they sound fine to me.
However... Please note that on the Plexi6V6 one triode uses components to give a normal sound and the other triode uses components that give a bright sound. So, while the 12DW7 would give the results you're looking for if both channels were identical, it will become more complicated if the channels are different as in the Plexi6V6. It could be the latest golden mojo sound of the year. Might be a disaster too!  :icon_biggrin:
Offline Rockranger
Re: V1 A and V1 B?
« Reply #4 on: February 06, 2019, 07:21:49 pm »
Sounds good I Will give it a shot! Thanks
Offline Rockranger
Re: V1 A and V1 B?
« Reply #5 on: February 09, 2019, 01:59:43 pm »
Sticking with the same idea using a 12dw7 in V1 what could you do in the case of a deluxe reverb style where you have the input going in one side and the volume in the other?
https://el34world.com/Hoffman/files/Hoffman_AB763_2.pdf
Re: V1 A and V1 B?
« Reply #6 on: February 09, 2019, 02:39:55 pm »
Nothing. The Hoffman AB763 amp is not a candidate for the 12DW7.
Offline Rockranger
Re: V1 A and V1 B?
« Reply #7 on: February 09, 2019, 03:53:36 pm »
Thought so, thanks again
