September 15, 2026, 09:38:29 am
Hoffman Amps Forum image Author Topic: Can you please explain my meter reading ?  (Read 7758 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: February 06, 2019, 06:48:12 pm »
Hi everybody, I'll be short and sweet. I started to bake my own bread and my wife is anxious to eat my baguette.
Ok to the point now.
I have made another nice sounding 50w guitar amplifier, el34 cathode bias.
The HT is fused on the center tap of the power tranny and to test the beast b4 it goes on the road I have put a Am meter in series with the HT fuse holder to check the current changes over a long period of time, more or less a stability test. What I don' t understand is this: ac current of 175 mA
 is surfing over a dc currentof 100mA ( more or less the sum of the power tubes K dc current.
Now, what size of fuse should I use ?  The sum of both currents plus a security margin ?
Omg my bread starts to smell
Thnx
Colas
P.S.: call me Alvin.
Re: Can you please explain my meter reading ?
« Reply #1 on: February 06, 2019, 06:56:37 pm »
I'd use a 1/2A Fast fuse.
  • MAKE LOVE NOT WAR
« Reply #2 on: February 06, 2019, 07:08:15 pm »
So the 500mA fuse corresponds to the sum of both currents x 2 more or less is that how we must calculate ?
You are more an expert than me in current calculationI am pretty sure  (but not in the bread baking though..
Thanx buddy
« Reply #3 on: February 06, 2019, 07:18:01 pm »
I thought you needed a fast answer. :wink:
1/2A Fast is a typical value I've seen used in 50W EL34 amps.
  • MAKE LOVE NOT WAR
« Reply #4 on: February 06, 2019, 07:56:27 pm »
Yeah LOL
I TRIED A 250 mA it blew after a couple of sb switch throws
My meter showed a 130mA dC surge on powerup but we must add the ac current surge wich totalize over 300m A .  So a 1/2 A fuse is good as a matter of fact works fine on powerup and sb operation.
I was just surprised to see both ac and dc currents appearing on the pt center tap and to realize that the rectifier has an influence on the previous stage !!!!! After all a power tranny has both it s outputs working on ac not dc.
Colas Coca
  • MAKE LOVE NOT WAR
« Reply #5 on: February 06, 2019, 08:00:09 pm »
Correction : a pt has both it s input and ouput working on ac.
« Reply #6 on: February 07, 2019, 02:20:25 pm »
If it is working OK the load is much less than 0.5A.
If something shorts out the load will be MUCH more than 0.5A.
  • MAKE LOVE NOT WAR
« Reply #7 on: February 07, 2019, 03:24:48 pm »
Yeah I know. What I was surprised about is to find both ac and dc current at the pt center tap
« Reply #8 on: February 07, 2019, 03:36:34 pm »
What you have at the PT center tap is all dc. But it's pulsating dc that has not been filtered very well. Most meters think that is ac.
  • MAKE LOVE NOT WAR
« Reply #9 on: February 07, 2019, 04:17:00 pm »
Gee, I oughta write a letter to Mr Fluke about his shitty multimeter
Ok I understand your point sluckey but why my meter shows 175mA ac and 100 mA dc ?
Offline vampwizzard
    • Walbertedwards.com
« Reply #10 on: February 07, 2019, 07:24:02 pm »
the different values likely has to do more with how the meter is measuring the current. youre almost a perfect square root of 3 different.. tell tale sign.
Fuse wise, 125% overcurrent protection is standard for transformers and i usually round up if its inbetween normal values. The term for that DC spike is "inrush" current. It sucks but is a necessary accommodation.
« Reply #11 on: February 07, 2019, 08:26:46 pm »
Go down by the river. Where it meets the sea.
The river runs to the sea. Steady (direct) current.
The sea rises and falls with the tide. Alternating current.
They can both be in the same piece of water, or circuit.
« Last Edit: February 08, 2019, 05:20:43 pm by PRR »
« Reply #12 on: February 08, 2019, 05:43:08 am »
DO NOT SWIM there !!  :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #13 on: February 08, 2019, 02:59:33 pm »
Exactly like the guitar ac signal is taken from the plate dc voltage by the mean of coupling caps
