August 29, 2026, 03:56:49 pm
Hoffman Amps Forum image Author Topic: building a second 5f1 with a different power transformer (question)  (Read 5872 times)
Offline Shack
Hi all, been awhile since I have been on here, hope everyone is doing good. Anyway, I recently built a champ with the transformer 02277( 325-0-325 70 ma ) and the OT is  8k to 8 ohm. This amplifier sounds fantastic......so I want to build one for my other guitarist in the band. I have an old tranny I bought years ago, that has 250=0=250 at 70 ma, and I plan to use a GZ-34 rectifier instead of the 5Y3.
In order to get this amp as close to mine as possible, I should change the dropping resistor values correct? I ask because I bought this tranny to build the small single ended amp in the Dan Torres book but never did, and he used way lower resistor values in those plans, I just want to make sure before I place a parts order.
I hope this amp sounds alot like the one I just finished, because I am in love with the sound of that one.
New build problems? Click here.
Re: building a second 5f1 with a different power transformer (question)
« Reply #1 on: February 08, 2019, 10:31:36 am »
325 X 1.1 (5Y3) = 357.5 plate volts
250 X 1.3 (GZ34) = 325 plate volts
This is within about 10% and "shouldn't" make a difference in the power amp section.  Probably not much difference in the preamp either, but. . .
Smaller B+ dropping resistor(s) will enable you to match your plate voltages in the preamp section.  I would use Ohm's Law to calculate the preamp current draw establishing the preamp voltages in your amp.  Then use that info to calculate the dropping R value in the new amp.  (Though some here prefer guesstimation + trial & error).
Offline Shack
« Reply #2 on: February 08, 2019, 01:00:19 pm »
thank you, I need to write down all these formulas so I can figure out stuff like this without asking....so much math in electronics lol
« Reply #3 on: February 08, 2019, 01:35:28 pm »
here's a rectifier info chart.
also Ohm's Law is a must (I feel your pain.)
« Reply #4 on: February 08, 2019, 03:44:46 pm »
and here's the ohms law cheat-sheet
Offline Shack
« Reply #5 on: February 10, 2019, 08:44:32 pm »
so after a week or more of jamming this amp.....I played it with the band......and halfway through rehearsal, the sound went away. and I think the output transformer smoked on me, what would cause this, and where do I start to troubleshoot.? the amp appears to be built like a tank, and im about to start another, guess ill look at things tomorrrow, but it was working fine
My guess is that the old Sylvania 6V6 may have gone bad, because both transformers were hot when it went quiet, so when the new transformer comes in, ill fuse it ....its just going to set back my friends champ a week or so,lol
« Last Edit: February 11, 2019, 05:17:01 am by Shack »
« Reply #6 on: February 11, 2019, 07:48:00 am »
Always suspect tubes first.  Then test the OT.  If a tranny is bad, don't suspect the tranny itself was faulty.  Instead check for other circuit faults - like a short circuit - that may have fried the tranny.  Otherwise if a new tranny is installed, it will fry too!
Offline Shack
« Reply #7 on: February 11, 2019, 03:28:59 pm »
Yea, thats why I think that the old 6L6 is most likely the culprit, since it worked great and I so far cant see anything else to look suspect.
