September 15, 2026, 07:29:15 am
Hoffman Amps Forum image Author Topic: Fowler's Hot Rod Plexi #39  (Read 26097 times)
Offline purpletele
    • Vallis Enterprises, Inc.
« on: February 09, 2019, 12:48:10 am »
Next Amp on the Bench
Mark shared his files for a famous HRP that he has his own twist on.  I am starting that amp with the Dual 50 in the works as well.
Since the layout and Schematic is live at TAG, I don't think Mark will have any issue.  I sent him $20 and a Cuban cigar. (Did you get those yet Mark)
« Last Edit: February 09, 2019, 12:53:52 am by purpletele »
Offline Glenn
Re: Fowler's Hot Rod Plexi #39
« Reply #1 on: February 09, 2019, 08:35:32 am »
Get ready for a punch in the face!
Lol... I mean this amp is that. I built a 6v6 18 watt version of this.... love it.
Good luck with yours...Joe
Offline purpletele
« Reply #2 on: February 11, 2019, 12:47:31 pm »
A little Progress
Offline nandrewjackson
« Reply #3 on: February 11, 2019, 01:46:31 pm »
Looks like a nice build !
 :icon_biggrin:
Offline MFowler
« Reply #4 on: February 14, 2019, 07:26:53 am »
No cigar yet :icon_biggrin:
Looking good, can't wait for initial fire up and look on your face. :laugh:
Mark
Offline purpletele
« Reply #5 on: February 14, 2019, 09:57:08 am »
Mark
Mark,
I'll set up a camera for the start up.
Parts coming tomorrow that will allow me to get real close if not finish it up very soon.
Offline silverfox
« Reply #6 on: February 15, 2019, 09:01:05 pm »
Don't rush it.
silverfox.
Offline purpletele
« Reply #7 on: February 25, 2019, 02:56:20 pm »
Back on track, waiting for a few parts.
Offline purpletele
« Reply #8 on: February 28, 2019, 11:18:20 pm »
Stand Back It's Start Up and Testing Time.
Offline MFowler
« Reply #9 on: March 01, 2019, 08:30:33 am »
Going to be fun for about an hour playing time!
Mark
Offline purpletele
« Reply #10 on: March 02, 2019, 01:33:49 am »
Update on the HR Plexi
Up and running and really quiet.  I had some issues with the speaker jacks I used for the FX loop, changed that out and connected the tips of the FX loop jacks and the amp roared to life.
I had an issue with MV that I found and corrected, a ground wire was not soldered well to the buss.
I am going to test the FX loop to see if the jacks are working correctly, I tied the shunt to the tip.
I really like the FX Loop MV.
« Reply #11 on: March 02, 2019, 06:13:08 am »
Hey man! You're really turning them out fast these days. Looks great! Can you post a link to Mark's schematic?
« Reply #12 on: March 02, 2019, 06:25:33 am »
Fantastic job on the build!  Looks excellent.
I am wondering IF this might be the schematic?
« Last Edit: March 02, 2019, 06:29:56 am by tubenit »
« Reply #13 on: March 02, 2019, 09:35:26 am »
based on the layout attached to the opening post, i would say mostly yes, minus the "depth" control.
« Reply #14 on: March 02, 2019, 11:45:33 am »
Ha! It was hiding in between the pics. No fair!
Offline purpletele
« Reply #15 on: March 02, 2019, 01:46:59 pm »
I seem to be on a roll.  I have the Dual 50 right on the tail of this #39.
That will be it for a while, I have one heck of a cool collection of fantastic amps that are only worth half of their real value.  But I am rich in tone.
Offline purpletele
« Reply #16 on: March 02, 2019, 01:57:04 pm »
Jeff,
That is the schematic, it is hard to read but it helped me clarify some confusion on the layout.
I have the amp running at full performance and it is a Beast, I am sure you would really like it.
Mark's layout has a couple of subtle jumpers that you cannot see very well, but are quite visible when loaded into Visio, so if anyone takes on this amp feel free to ask for clarification.
I like the long board layout, but the board ends up being 18", so you need a 20" chassis.
Good fun amp project, tough to build in a JTM Chassis though.
BV
Offline MFowler
« Reply #17 on: March 03, 2019, 10:04:36 am »
Based on original schematic from Stephan (Darkbluemurder)
Added depth pot and power section is JCM800 2204 or 2203
Mark
Offline purpletele
« Reply #18 on: March 03, 2019, 01:36:40 pm »
Project Update
I took a break from this amp and worked on another project.
After thinking about the instable voltage that I have on V4-6 I am wondering if I have a .1 Cap that is not holding it's charge.
I also have a strange issue when I engage the boost it has a note decay that doesn't exist when not engaged.  I am wondering if i am on the right track to assess the voltage instability.
This amp is really going to be a beast if it is only pumping 7 cylinders.
« Reply #19 on: March 03, 2019, 02:10:21 pm »
V4-6 should be just as stable as V4-1. And the steady dc voltage should be about the same on both plates. Maybe check the jumper between pin 3 and 8?
Can you produce a clean sound with that amp?
Offline purpletele
« Reply #20 on: March 03, 2019, 02:32:41 pm »
Yes, the amp is quite responsive, so if I turn the gain down, thurn up the master and roll back the guitar volume it cleans up as anticipated.
Offline purpletele
« Reply #21 on: March 03, 2019, 02:53:02 pm »
Here are a couple of photos of the target area
The voltage on V6-7 is 41 V
The voltage on V5-7 is 41 V
« Last Edit: March 03, 2019, 02:58:24 pm by purpletele »
« Reply #22 on: March 03, 2019, 03:00:20 pm »
Resolder the jumper between pins 4 and 5. Resolder the jumper between pins 3 and 8. Replace the plate resistor for pin 6. Any better?
Offline purpletele
« Reply #23 on: March 03, 2019, 03:36:03 pm »
I did that work without results.  I changed the .1 Cap without change, I pulled the plate resistor and checked it and replaced it and tested, no change.
I changed the 100pF Cap tying the two tails together, I don't know if it was the process of refloating or if it was a bad cap, but I have 202 V now on V4-6, and the amp feels and sounds a tad better.
I was hoping that the voltage issue might resolve a decaying note issue with the boost engaged, but it didn't.  I am going to redo some of the work around that boost.
Update I didn't resolve the decaying note under Boost issue with the clean up work.  I may eliminate it altogether, I like it but I like using a variable clean boost on the board for that.
With exception to the boost, the amp is complete and sounds really hot!
« Last Edit: March 04, 2019, 12:40:31 am by purpletele »
Offline purpletele
« Reply #24 on: March 04, 2019, 12:49:34 am »
Here is the new configuration for the Fowler #39 Beast.
The guitar has also been recently hatched.  I had a body made by Musicraft with super lightweight Swamp Ash.  They sent it to MJT for a nitro finish.  I like the Charvel necks so I bought one from Stratosphere.  It's a nice guitar, needs a little fret work, but it feels nice and it rips.
The amp is a living breathing monster, pretty fun.  The amp is really quiet.  My board is too tight to try to trouble shoot the Boost, I think it will be one of those things that goes away.
After the troubleshooting and resolving the chaotic voltage, I am getting 485 on the plates and I have the bias set at 36 mV.
Offline MFowler
« Reply #25 on: March 05, 2019, 10:00:33 am »
That boost switch engaged is where myself and the guys that have one of my HRP amps play most of the time for those harmonic Rock God tones.
The switch marked Boost is just switching a .68uf bypass cap in and out for a sweet boost.  Both the cap and resistor connect to ground and then each is wired to the mini switch with 4m7 resistor.  The mid boost is just switching between two 10k caps in parallel for either 5k or 10k.  I don't use it as much as the 2nd Boost switch.
Like you said you can lower the gain and crank up the master and it will clean up.  You could add a 1k8 resistor to the end of the gain pot to ground as a stop so it's easier to turn down on the fly the gain won't completely turn off that way.
Glad you have your amp up and running but it can sound better just keep working at it.  Resolder the terminals might help.
Mark
« Last Edit: March 05, 2019, 10:04:03 am by MFowler »
Offline Glenn
« Reply #26 on: March 05, 2019, 12:26:15 pm »
Brian and Mark: does the boost add hiss?
I love mine but I get more hiss, the mid boost is ok but the slap in the face boost is great. I replaced the wiring but the hiss is still there
this is a great amp, and nice work on yours Brian
sorry didn't mean to derail
Offline purpletele
« Reply #27 on: March 05, 2019, 02:53:36 pm »
I don't get a hiss from my boost, I get a decaying note.  So if you hit a note and it is sustaining, it will just cut off.
I also have a deep six feedback now when I hook up my FX cables.
I do like the boost, so I will find the issue of the decaying note.
Offline purpletele
« Reply #28 on: March 05, 2019, 03:10:04 pm »
Mark
I'll keep working at it Mark.  I learned a few things about Turret boards this last go around.  I learned that I am not giving myself enough room to do clean work.
I really like the amp!
Just a few more tweaks and I'll be there.
« Reply #29 on: March 05, 2019, 03:20:47 pm »
Nice work.  I love the CF Tone Stack.  Wouldn't want to lose any gain from the 4 triodes proceeding it. :l2:
Will it play clean, Sluckey asks?  Well I guess you could relay switch out 3 triodes in the preamp and make it similar to a 1987.
Turn it up!  Gonna have a bit of tweaking to get it just right.  Take you time.  I can tell the how to build an amp understanding has grown a lot.  Good for you, maybe.  I hesitate to congratulate anyone on developing an Addiction.
really, nice work.
Offline purpletele
« Reply #30 on: March 05, 2019, 08:01:48 pm »
really, nice work.
I just took up Smoking Marlboro Reds and I love it.
I didn't, but it sounds funny.
I am an addicted builder of things.  I am going to build a couple of Storage Facilities and that type of construction has gotten real specialized with Light Gauge metal studs.  Should be fun, I mange the deals for owners.
« Reply #31 on: March 05, 2019, 10:20:12 pm »
Smokin OPs:
Offline MFowler
« Reply #32 on: March 05, 2019, 11:14:30 pm »
In my 100w versions for some reason I switched V1 to 12AY7 or 5751 to lower that hot gain.  The amp will hiss, it's a 4 gain stage amp. Actually 4 1/2 stages.
Mark
Offline purpletele
« Reply #33 on: March 08, 2019, 01:07:18 am »
Mark
That boost has me perplexed, but that happens quite often on these amps.
I replaced the resistor as well as the .68 cap.  I had stripped it down to bare turrets and rebuilt it and resoldered the switch wires.
I get a static and a quicker cut of on note sustain.  The only thing left to replace is the switch.
Would I be getting a note decay from a switch?
Offline MFowler
« Reply #34 on: March 08, 2019, 11:01:39 am »
Well that resistor and bypass cap is the bias for that preamp tube stage so funny noise is possible.
Mark
Offline purpletele
« Reply #35 on: March 09, 2019, 02:06:13 am »
I wrestled the boost circuit and finally won.  I changed every component without a change, changed the switch and resistor on the switch, no change.
I had 22 gauge hook up wire so I tried 20 gauge and that made the difference.  Maybe it was the surface area at the connections, or lack thereof that was causing the decay.
Offline purpletele
« Reply #36 on: March 09, 2019, 11:46:26 am »
Worked through the FX loop issues that I had.
I installed a switch to close the circuit when the FX loop is not in use.
The amp is working very well now, the boost and Mid boost are working fine and the amp is smokin.
Thanks for the help
BV
Offline MFowler
« Reply #37 on: March 14, 2019, 08:56:43 am »
try this
Offline purpletele
« Reply #38 on: March 14, 2019, 11:19:38 am »
try this
Thanks Mark.
I have to work, I'll be back later
BV
« Reply #39 on: March 14, 2019, 01:37:36 pm »
If you guys have any layouts you would like me to add to the .diy file library, let me know.
This is how custom boards are created from layouts
I can then make the custom board on my CNC machine
Offline purpletele
« Reply #40 on: March 14, 2019, 02:30:54 pm »
I saw the video the other day, that is a nice tool.
I was going to try and copy the layout the Italian Guys developed for the Friedman Smallbox 50.  I placed the file in the Hoffman folder, but I haven't tried the new tracing program.
BV
« Reply #41 on: March 15, 2019, 07:24:32 am »
BV
What is the Hoffman Folder?
« Reply #42 on: March 15, 2019, 09:24:07 am »
I don't mean to hijack your thread
I was just playing around with this amp layout in DIYLC
Since I am using components that are sized exactly to the real life parts, I noticed a few things
The filter caps do not fit on the original board layout in the PDF
That's one of the handy thing DIYLC can do when you are creating a layout
You can get the board the exact length you need by using parts that are 100% scale
I added the PDF image as a background and then added eyelets and parts
The image is pretty large and may not look good scaled down here
Offline purpletele
« Reply #43 on: March 15, 2019, 06:03:55 pm »
I found that out as well on my first board.
Mark's boards are around 17" long.  The chassis that I had was about 17", I tried to compress it but failed miserably with the caps.
« Reply #44 on: March 16, 2019, 07:06:23 am »
Looks like you did what I would have done.
Used a 40x20x20x20 can cap  :icon_biggrin:
Offline MFowler
« Reply #45 on: March 17, 2019, 07:48:36 am »
My boards are 19.75" long x 2.875 wide and I have changed my layout 4 times to better fit the wiring layout.
Mark
« Reply #46 on: March 17, 2019, 07:53:58 am »
Mark
Yeah, that's a super long board
« Reply #47 on: April 25, 2019, 12:27:32 pm »
try this
Is the wiring diagram stating to use a shorting switchcraft preamp out and a non-shorting power amp in.  I get this.  The connection points, to confirm. Preamp tip connected to the intersection R37 and C14.  Switch and tip connect.  Finally for the long run to the Volume pot use shielded wire and connect to the wiper prior to R37?
Please let me know as I have a 2204 I just added the boost to and tweaked it a tad.
Offline MFowler
« Reply #48 on: April 29, 2019, 12:03:38 pm »
For Switchcraft I think that 1st example is wrong you could not use the power amp in by itself.  I would follow the 2nd example and put the switched jack on the send.
For Cliff jacks in a JCM800 I use the interrupt style effects loop.
See Ceriatone's layout
« Last Edit: April 29, 2019, 12:08:52 pm by MFowler »
Offline purpletele
« Reply #49 on: April 29, 2019, 06:24:29 pm »
Mark
Sure looks good now
