August 29, 2026, 03:58:33 pm
Hoffman Amps Forum image Author Topic: Squealing amp  (Read 4978 times)
Offline newguitarsmell
Squealing amp
« on: February 12, 2019, 09:58:39 pm »
I have had a little point-to-point wired boutique amp for awhile. It is very cool in that is can use a variety of tubes. No, I do not have a schematic ...
I recently swapped out the 6188 tube for another and now it squeals when I first turn it on. I changed all the tubes and it is a little better - as I turn the volume up the squeal disappears.
I can't get the case open to take gut shots.
 :BangHead: :BangHead:
Is it worth drilling out the screws to get it open? What causes that squeal?
Offline Slimtim
Re: Squealing amp
« Reply #1 on: February 12, 2019, 10:07:03 pm »
yeah if you want to fix it you gotta open it up unless it is a tube.why can't the screws be unscrewed?
Re: Squealing amp
« Reply #2 on: February 12, 2019, 10:11:20 pm »
A couple are pretty tight but I can try harder. I'm afraid they might strip.
Re: Squealing amp
« Reply #3 on: February 12, 2019, 10:14:51 pm »
Put the old tubes back in it.
Re: Squealing amp
« Reply #4 on: February 13, 2019, 05:36:11 am »
What he said, especially the one you swapped out first. I love those 6SL7 (6881) but they can be quite noisy, and make all kinds of weird sounds. I have a few that after 5 mins of playing start to make a whistling sound. The damping rings help. Or just putting in a quiet one ;)
