September 17, 2026, 10:53:26 am
Hoffman Amps Forum image Author Topic: SluckeyAmps 1960 Vox AC15 Build  (Read 58663 times)
Offline SkipJohnson
Re: SluckeyAmps 1960 Vox AC15 Build
« Reply #100 on: April 04, 2019, 11:45:50 am »
What is the ground for in the red circle?
Exactly how many ground connections to the chassis do you have, 2, 3, 4, 5?
That was Ground Scheme 1.2 (i.e. part of a partial implementation og Slucky's suggested changes to the grounding scheme).
I later re-did the entire ground scheme (GS 2.0), this chassis ground connection is no longer there.
Skip Johnson
ZTUBEZ Amps
Offline SkipJohnson
« Reply #101 on: April 04, 2019, 11:50:36 am »
Four as follows:
1) AC Power Cord Ground
2) Power Amp Ground
3) Control (Preamp) Ground #1 (volume pots)
4) Control (Preamp) Ground #2 (Effects and inputs)
Skip Johnson
ZTUBEZ Amps
Offline SkipJohnson
« Reply #102 on: April 04, 2019, 11:52:58 am »
Can we see some pictures of the whole amp, inside? And I'd like to see where the speaker jacks are and whats next to them.
And some pics of the back side of the chassis, showing the PT/OT?
Will do.
I have been trying to catch up on all the replies on this thread, and I need to complete the power section changes you suggested first.
Pictures will be later today.
thx!!!!!!
Skip Johnson
ZTUBEZ Amps
« Reply #103 on: April 04, 2019, 12:25:57 pm »
Chassis grounds 3 and 4 should be combined together into 1 ground.
Offline SkipJohnson
« Reply #104 on: April 04, 2019, 12:29:35 pm »
Will do.
thx!!!!!!
Pictures are ready for viewing at:
https://www.flickr.com/photos/23805934@N02/albums/72157690742479393
Skip Johnson
ZTUBEZ Amps
Offline SkipJohnson
« Reply #105 on: April 04, 2019, 12:30:49 pm »
I'll work on that.
Skip Johnson
ZTUBEZ Amps
« Reply #106 on: April 04, 2019, 12:31:18 pm »
Why did you remove that ground connection? SEE PIC...
Offline SkipJohnson
« Reply #107 on: April 04, 2019, 12:35:32 pm »
Both the terminal strips are connected directly to the chassis now, NOT isolated.  Per Willabe I plan to combine these into a single terminal strip near the input jacks (where the 5 lug is now).
Skip Johnson
ZTUBEZ Amps
« Reply #108 on: April 04, 2019, 12:39:24 pm »
Are all the lugs on those terminal strips strapped together?
« Reply #109 on: April 04, 2019, 12:58:28 pm »
Sluckey meant to run the OT secondary wire around the end of the board, not all the way around to the chassis end.
Now you have that wire laying on the ac power and other things.
Offline SkipJohnson
« Reply #110 on: April 04, 2019, 03:24:31 pm »
Yup
Skip Johnson
ZTUBEZ Amps
Offline SkipJohnson
« Reply #111 on: April 04, 2019, 03:25:36 pm »
OK.  I'll fix that.
Skip Johnson
ZTUBEZ Amps
« Reply #112 on: April 04, 2019, 03:52:56 pm »
Has anything you have done today affected the top cut hum issue?
Offline SkipJohnson
« Reply #113 on: April 04, 2019, 04:07:28 pm »
Nope  :BangHead:
I re-re-routed the yellow OT wire around the board instead of the end of the chassis.
I am in the middle of changing the two control ground terminal strips into one 7 lug under the input jacks.
Skip Johnson
ZTUBEZ Amps
« Reply #114 on: April 04, 2019, 06:52:01 pm »
Measure resistance from pin 2 of each EL84 to chassis. What do you have?
Offline SkipJohnson
« Reply #115 on: April 05, 2019, 09:38:32 am »
Finished re-working the preamp ground from two terminal strips to one.  Stay tuned for results (things have changed for the better).  I will post results when I complete a set of tests.
Here are the EL84 Pin 2 resistance readings:  221k ohms on both tubes.
Skip Johnson
ZTUBEZ Amps
« Reply #116 on: April 05, 2019, 09:48:01 am »
since ur testing.............
play something;
remove the cap on the PA tubes cathode, play again;
Did the hum decrease with overall gain drop from pulling cap?
add a BIG cap, something 2, 3 X's bigger, gatorcippin is fine
any change
Offline SkipJohnson
« Reply #117 on: April 05, 2019, 09:57:04 am »
play something;
any change
Hold that thought...……………
As I said, things have changed.  I am methodically testing and documenting and will post in a bit.
Skip Johnson
ZTUBEZ Amps
Offline SkipJohnson
« Reply #118 on: April 05, 2019, 12:08:19 pm »
I completed all the changes discussed over the las couple of days including re-working the preamp ground from two terminals to one.
The result of this last change or a combination of the recent changes is that the HUM is gone!!!!!   :icon_biggrin:
I have performed a series of tests.  The details can be viewed in the attached Test Notes.PDF file.
Bottom line is I have a couple issues to address as follows:
   1) Major Items
      a. Effects Not Working
   2) Minor Items
      a. Some Nor/Vib Vol Noises
         i. The noises are eliminated by setting the Top Cut above 2.5
         ii. This is similar Top Cut behavior when the loud Hum issues was present
I think the effects issue will be solved fairly easily as they worked before I did a last few changes, so I (think I) know where to focus.
The other Volume related noises are a nuisance and seem related to the gremlin we have been chasing.  But I'll keep working it.
Thanks for all the help so far EVERYONE, especially Slucky and Willabe.  :worthy1: REALLY appreciate it.
Skip Johnson
ZTUBEZ Amps
Offline SkipJohnson
« Reply #119 on: April 05, 2019, 12:22:06 pm »
BTW: I think that the one change I made that might be the fixer was moving the PI ground from the power amp ground to the preamp ground.
Skip Johnson
ZTUBEZ Amps
« Reply #120 on: April 05, 2019, 12:39:01 pm »
 :thumbsup:
gonna  :hijack1: for a quick clarification
Since PP PA's tend to noise cancel, would the "sharing" of cathode parts "lessen" that cancelation  :dontknow:
thanks
« Reply #121 on: April 05, 2019, 12:48:27 pm »
:thumbsup:
Since PP PA's tend to noise cancel, would the "sharing" of cathode parts "lessen" that cancellation  :dontknow:
That's a good question.
I would think no.   :think1:
« Last Edit: April 05, 2019, 12:58:05 pm by Willabe »
« Reply #122 on: April 05, 2019, 01:10:06 pm »
PP PAs have common mode rejection due to the OT. This means that if the same signal appears on both inputs that signal will be cancelled in the OT. That same signal might be power supply hum. Or it might be some other stray signal/noise picked up in the air. But for it to cancel it must appear on the top and bottom of the OT. For it to cancel perfectly, it must be identical. This is one reason that it's important to have equally balanced tubes and perfect OTs. I don't think a properly bypassed cathode resistor will be a factor.
Offline SkipJohnson
« Reply #123 on: April 05, 2019, 05:15:41 pm »
OK, back at the bench.
I found the issue with the effects not working.  As soon as I looked at that area closely I saw that I have the depth pot slights twisted off center, causing the resister between the speed and depth pots to make contact with the right post of the depth pot.  A quick straightening of the depth pot corrected the situation.
So the only remaining issue is the minor Volume Pot noises.  With the top cut turned up past 2.5, these are eliminated.
I am calling it good until someday these bother me enough to dive in some more.
Thanks for everyone's help.  You all have been super helpful and relentless.  I hope I can be as helpful to someone with issues I can help with.
Skip Johnson
ZTUBEZ Amps
« Reply #124 on: April 05, 2019, 05:43:32 pm »
You really did a super job on this project. I hope you enjoy it. I know Ed's gonna start talking Celestion Blue so I'll kick it off for him. They are pricey but they bring out a lot of good in this amp, especially the EF86 channel.
Offline SkipJohnson
« Reply #125 on: April 05, 2019, 06:02:22 pm »
I was going to put this atop my Fender Custom Shop 2x12, but I like the idea of a speaker that is "One of the most famous speaker voices of all-time, helping to define the '60s British Invasion".  Just ordered one on Amazon that will be here on Sunday.
Thanks again!!!!!
Skip Johnson
ZTUBEZ Amps
Offline ElusiveMoose22
  • If you build it, it will hum.
« Reply #126 on: April 08, 2019, 02:15:59 pm »
Glad you got everything squared away finally!  Way to stick it out and trouble shoot that hum  :thumbsup:
Any vids or audio of what this thing sounds like now that you're done?  Let us bask in the glory of that classic EL84 overdrive lol :headbang:
Also I'm curious how your EF86 channel sounds.  Working on an amp project with EF86's in the preamp myself right now and I'm curious how other people are finding the sound to be in their amps.
Offline SkipJohnson
« Reply #127 on: April 08, 2019, 04:10:42 pm »
Finished my head and speaker cabinets today.
Amp - https://www.flickr.com/photos/23805934@N02/47567024481/in/dateposted-public/
Head - https://www.flickr.com/photos/23805934@N02/47567023881/in/dateposted-public/
Speaker - https://www.flickr.com/photos/23805934@N02/47567023831/in/dateposted-public/
Celestion Blue - https://www.flickr.com/photos/23805934@N02/47567024071/in/dateposted-public/
Sounds amazing.  The normal channel is really loud, responsive and the overdrive is awesome.  The Vib channel is also great.  Alot less volume, but the analog vib/trem effects sound great.
I am used to the vintage Fender amps I have been building, what a difference.   I still like the Fender sound, but this is really a different ballgame.
I also tried plugging the amp into my Genz Benz 2x12 speak cab.  Sounds really different, but it is a ported cabinet.  The G/B sounds bigger, the Celestion Blue (in a sealed cab) sounds a lot tighter.
Anyway, I am really glad I did this project.  I love the amp, I learned a ton and REALLY appreciate and respect the folks who helped me out begugging this beast.
I'll see about posting some video, I am relatively shay about my playing So I'll see.
As for the EF86 channel, it is nothing like the Fenders I have been building.  As I said above, this thing is really loud, responsive and overdrives really early when [playing with a heavy hand, and clean when lightening up the play.
In my opinion, you cannot go wrong with the EF86.
Skip Johnson
ZTUBEZ Amps
« Reply #128 on: April 08, 2019, 05:32:14 pm »
Very nice! I like putting the chassis on display in that head.
