September 08, 2026, 04:40:56 pm
Hoffman Amps Forum image Author Topic: Help, component identification  (Read 7023 times)
Offline whoops
« on: February 16, 2019, 08:01:47 am »
Can anyone please help me identify this component ?
My MK-328 says it's a 100pf capacitor
My Peak says it's a Diode
My multimeter doenst measure anything on Diode mode (both ways)
If it's a Diode it seems the Cathote is on the + mark, and the anode is on the "-" mark, pretty weird
Offline Papa Jim
Re: Help, component identification
« Reply #1 on: February 16, 2019, 08:19:20 am »
Is it waxed like a vintage cap?
Offline whoops
« Reply #2 on: February 16, 2019, 09:29:05 am »
It seems to have a card/paper like inclosure, and it's waxed or was impregnated with varnish
thanks
« Reply #3 on: February 16, 2019, 09:38:16 am »
There are a gazillion interesting/oddball shaped components once you step outside of the tube guitar amp world. No telling what it really is. The polarity markings would suggest diode or cap. I'd tend to lean more toward the diode guess. Then I'd throw it in the round file.   :icon_biggrin:
BTW, it was common in the early days of diodes to mark the cathode end with a plus sign.
Offline whoops
« Reply #4 on: February 16, 2019, 09:58:07 am »
Thank you so much Sluckey
so if the component is a Diode, and if the Cathode end is marked with a plus sign (+), then the schematic would be like this:
Component in question marked in read
Does this makes sense? I don't see much sense in a capacitor being in that spot, what do you think?
« Last Edit: February 16, 2019, 10:47:33 am by whoops »
« Reply #5 on: February 16, 2019, 10:40:46 am »
Does this makes sense?I don't see mush sense in a capacitor being in that spot, what do you think?
yes - 1/2 wave rectifier.
Offline whoops
« Reply #6 on: February 16, 2019, 10:48:40 am »
Thanks,should I change it for a full wave rectifier?
« Reply #7 on: February 16, 2019, 11:21:43 am »
No. Just replace that diode with a common 1N4007.
« Reply #8 on: February 16, 2019, 11:24:00 am »
what would be the benefit? worked as was for quite a while. replace the diode with a fast switching uF4004 or better if you want lower noise. if it were mine, i'd drop a 1n4007 (overkill) in it because that's what i have on hand... :D
Offline whoops
« Reply #9 on: February 16, 2019, 11:41:19 am »
Thank you,yes 1N4007 it goes,it's what I have in stock also
