September 17, 2026, 03:06:27 pm
Hoffman Amps Forum image Author Topic: Hoffman 5f1/More Clean Headroom  (Read 7235 times)
Offline jamaio
  • The search for tone is endless...
« on: February 16, 2019, 12:05:12 pm »
I built the Hoffman 5f1 2 years ago and the amp has performed well. I used a Fender Sidekick Reverb 35 as a donor for the cabinet and chassis. When I first built it I did not expect much and I bought a cheap speaker just to fill the hole, a Celestion Rocket 50. I started experimenting with different speakers, I have a Deluxe Reverb Cabinet with 2 Jensen C10Q speakers, I plugged those speakers into the 5f1 and the tone I get is awesome so I ordered a Jensen C12Q for the 5f1. The sweet spot for tone is with the volume at 6.5, however, there is more distortion then I like. I replaced the 12ax7 with a 12at7 and that cleaned up the distortion at the same volume level. I don't think I lost much volume or tone but I was wondering if there was a better way to smooth out the distortion, or maybe a better preamp tube. I am using a Fender Strat with single coil pickups plugged straight into the amp, using the neck and middle pickups. The tone I am looking for is tight lows, bright highs and scooped mids with a little crunch. I am not looking to be a rock star, I don't play with a band, just entertaining myself in my living room.
For reference I built the amp to Doug's specs: https://el34world.com/Hoffman/files/Hoffman_5F1.pdf
Here is a link to my build: http://el34world.com/Forum/index.php?topic=21444.msg227532#msg227532
« Last Edit: February 16, 2019, 12:32:14 pm by jamaio »
John
Hoffman Blues Junior, Hoffman 5F1 Champ, Hoffman Deluxe Reverb, Hoffman Stout Reverb, 1967 Fender Bassman, 1966 Fender Bassman, 1971 Fender Twin Reverb, Mojotone Princeton Reverb, 2012 PRS '58 Stripped, 2006 Fender Highway One Strat
Re: Hoffman 5f1/More Clean Headroom
« Reply #1 on: February 16, 2019, 12:54:14 pm »
You're probably at the limit of clean with that amp. A different speaker can get some more clean listening volume. JBLs and Electro-Voice come to mind.
I got one of these a while back. Loud, clean, excellent low end and good high end. Mids are good too, but any crunch/breakup you get will be coming from that amp, not the speaker.
https://www.amazon.com/Electro-Voice-Unpowered-Speaker-Cabinet-EVM12LCLSC8/dp/B000Z33HYI/ref=sr_1_6?ie=UTF8&qid=1550342681&sr=8-6&keywords=evm+12l
I also have a Weber California 12 that has a good clean sound with tight bass, strong mids and clear highs. No breakup.
Offline jamaio
« Reply #2 on: February 16, 2019, 01:52:57 pm »
Thanks for the reply!! I thought that might be the case.
The Jensen C12Q I ordered will be in next week, I will see how it sounds. I may order a 5751 pre amp tube to try, it will pass the same current as the 12ax7 but with a gain factor of 70.
I have also tried using a TS-808 Tube Screamer with the gain set at 2, tone on max and the volume set at 7. I get more clean highs and sustain but less lows. I also have to have the amp volume set at 3 to keep distortion down.
I will let you know how it sounds with the new speaker and different tubes, 12at7 and 5751.
John
« Reply #3 on: February 16, 2019, 02:05:54 pm »
12AU7 and 12AY7 are also candidates. I think the speaker is gonna do the trick for you. I have a C12N in my 5E3 and like it pretty good.
Offline Slimtim
« Reply #4 on: February 16, 2019, 08:01:26 pm »
i second everything steve said.the ev speakers are great.had a 15l i'll kick myself forever for getting rid of.also i use a 12au7(6189 actually) in v1 in my ao35 alot.also switch out an old 5star 5751 sometimes.
Offline jamaio
« Reply #5 on: February 23, 2019, 08:16:30 pm »
I finally found time to install my new speaker, Jensen C12Q8, and it sounds awesome. I am using the 12AX7, the low end is very punchy so I was able to turn the volume down to clean up the distortion without losing tone.
Thanks for the suggestions.
John
Offline jamaio
« Reply #6 on: February 27, 2019, 07:54:54 pm »
Today I replaced the 12ax7 with a 5751, I tested the volume of both tubes with an SPL. I had a little more than 1 dB drop with the 5751, however, the distortion cleaned up nicely. I am able to get clean tones up to 7 on the volume, after that the natural breakup is very smooth. I cranked the volume to max, "12", and played the intro to "Smoke on the Water", the amp sounds awesome!! I am playing a Strat with single coil pickups, neck and middle, plugged straight into the amp.
I am very pleased with the new speaker and the 5751 preamp tube.
 :guitar1  :headbang:    :guitar1
John
