September 17, 2026, 08:28:48 pm
Hoffman Amps Forum image Author Topic: Adjustable Amp Voltage  (Read 4335 times)
Offline Papa Jim
« on: February 27, 2019, 06:04:38 am »
I want to build a chassis to experiment with modifying and building different amps onto. Extra switch selectable wired up paralleled sockets for quick preamp tube comparisons, adjustable NFB, adjustable B+ voltage, etc. etc. Is there any downside other than space required to use pots for B+ voltage changing, and NFB  values?
Re: Adjustable Amp Voltage
« Reply #1 on: February 27, 2019, 08:11:15 am »
Papa Jim
Sounds like you are ready to get serious.  Check here for some ideas.
https://el34world.com/Forum/index.php?topic=15445.0
« Reply #2 on: February 27, 2019, 10:41:42 am »
Maybe a breadboard instead of a chassis.
Weber sells a PT with a variety of secondary voltages.  You could also use a variable bench power supply.  The downside is that exact tranny selection will affect amp performance & tone.
