September 15, 2026, 12:22:36 am
Hoffman Amps Forum image Author Topic: VOX AC30C2 No Sound  (Read 7668 times)
Offline dpm309
    • Matthews Amps
VOX AC30C2 No Sound
« on: March 05, 2019, 04:37:04 pm »
Have a Vox AC30C2 with no sound. Both pilot lights light up and all of the heaters on the tubes are glowing. I am getting proper voltages on the tubes so the PT seems to be functioning properly. I am suspecting the OT but was wondering if there is anything else I should be looking at. Plate voltage (pin7) on the power tubes is 328VDC and 305VDC on Pin 9.
Offline Papa Jim
Re: VOX AC30C2 No Sound
« Reply #1 on: March 05, 2019, 04:49:39 pm »
What kind of test equipment do you have to check it with. A simple audio probe easily built with a couple parts will take you a long way into pinpointing the spot of signal loss. a guitar as your signal source, audio probe, and a working amp for the audio interface to your ears. About as simple as it gets but does work if no other equipment is available. Not recommended unless you are skilled working around the lethal voltages present in amp circuits.
« Last Edit: March 05, 2019, 04:55:35 pm by Papa Jim »
« Reply #2 on: March 05, 2019, 04:51:27 pm »
Zero sound? Bad speaker jack??
Offline Papa Jim
« Reply #3 on: March 05, 2019, 04:56:35 pm »
Volume pot turned down? Just had to ask.  :l2: :l2:
Offline dpm309
    • Matthews Amps
« Reply #4 on: March 05, 2019, 05:26:16 pm »
I get absolutely no sound even with the volume turned all the way up. The speaker is hard wired into the amp. I have a listening amp/audio probe that I was planning on using to determine where the signal gets lost. Will also run a couple of tests on the OT.
Offline Papa Jim
« Reply #5 on: March 05, 2019, 05:50:01 pm »
Cool. Sounds like you were looking more for some common problem with these amps the forum knew of vs more general troubleshooting help. Good luck with the probe. Keep us up to date with what you find. May be something we can use in the future.
« Reply #6 on: March 05, 2019, 05:54:32 pm »
Check the cliffs for send/return, looks like in the schematic if they get boogard no sound.
make sure you got tube glow, the pre's use  DC fil, the last on I worked on had toasted filament stuff on the DC side
Offline dpm309
    • Matthews Amps
« Reply #7 on: March 06, 2019, 01:39:02 pm »
All the tubes are glowing. Cleaned the send/return jacks, tried the bypass switch and jumpered the loop jacks with no luck. Ran some simple output transformer tests which did not indicate any problems. I then ran a shorted winding test. The bulb lit up on the primary side (good) but did not light up on the secondary side. I ran this test with all of the leads disconnected. Will try the audio probe this afternoon when I get some time.
Offline dpm309
    • Matthews Amps
« Reply #8 on: March 07, 2019, 12:34:50 pm »
Double checked the voltages on the preamp and power tubes - 3VDC for the preamps and 3.1VAC for the power tubes. I checked out the speakers using  9V battery and they are both working. Also plugged an extension cabinet in and did not get any sound.  Using the audio probe, I get signal right up to the OT, but nothing after.  Looks like the OT is fried.
