September 15, 2026, 05:20:36 am
Hoffman Amps Forum image Author Topic: 5E3 Build  (Read 4639 times)
Offline 82lespaul
5E3 Build
« on: March 05, 2019, 07:29:32 pm »
Hello.  Just completed a Mojo 5E3 build and I have a few questions.  The forum members provided great assistance on my 62 Gibson Falcon restore so I'm back.
The power transformer is Mojo 756 with a rated 384v @ 75 mA secondary.  No heater CT so I did the two 100 ohm resistors from pilot light to ground.  I am performing first power on with no tubes installed and plugged into a DBT.
Wall voltage is 121VAC.  I measured 121.3 VAC at fuse holder to chassis ground.
The rectifier heaters measure 5.77 VAC (is this too high?)
The power tube heaters measure 7.41 VAC (V3 and 4).  is this too high?
The pre amp heaters measure 7.35 VAC (V1 and 2).  Is this too high?
Lastly, the  high voltage secondary at the rectifier (pin to chassis ground) measure 397.9 and 397.6, respectively.  Is this to high?
I do not want to continue and power up with rectifier tube till I am sure.  I let the amp run for at least 20 minutes while I measured and everything seems fine.
Any advice is greatly appreciated.
Doug
Re: 5E3 Build
« Reply #1 on: March 05, 2019, 07:48:11 pm »
It's normal for all voltages to be high when no tubes are plugged in. I'm not concerned.
Offline 82lespaul
Re: 5E3 Build
« Reply #2 on: March 05, 2019, 08:12:31 pm »
As always thanks for the quick response.  I will proceed with the rectifier tube.
