September 20, 2026, 10:07:42 pm
Hoffman Amps Forum image Author Topic: Dual Plexi / October & JCM800 Build  (Read 5884 times)
Offline tristanc
« on: March 16, 2019, 12:41:28 pm »
Just sharing my latest build. My first to use a set of modular PCBs I designed to allow quick and easy design changes should I wish.
The modules are for Preamp, LTPI, Effects Loop, Reverb, Tone Stack and Power Supply. I followed a fairly anal grounding scheme, keeping chassis and audio grounds separate throughout & filter caps close. As well as trying to keep the PCB layout as close to an ideal point-to-point style as I could. I'm going to make the KiCad files and Gerbers available on GitHub or similar so others can take and modify / use...
This is an AX84 October & JCM800-style build using a pair of 6V6s, with two inputs as suggested in Sluckey's Dual Marshall. I made a few tweaks here and there based on Merlin's books and used his Bone Ray tone stack as well as the 'Scale' control he describes.
I also added a solid state effects loop and internal reverb using a Belton module usually seen in pedals.
The goal was for a loud amp that takes pedals reasonably well for use with a band. I think I've achieved that. The reverb works really well. It's loud. And a bit of boost in front makes the JCM 800 input scream. The October input gives lovely cleans.
I've a new set of 6V6s incoming and will do some preamp tube rolling, but won't spend too long on it as it's pretty much there.
Schematics and BOM: https://www.tristancollins.me/ax84/Mutineer/Built/
Tristan
« Last Edit: March 16, 2019, 12:44:08 pm by tristanc »
Offline Auke Jolman
Re: Dual Plexi / October & JCM800 Build
« Reply #1 on: March 16, 2019, 12:53:55 pm »
Nice build. Something different as to what we see mostly here.
Where did you buy the PCB's?
With Regards,
Auke
Offline tristanc
« Reply #2 on: March 16, 2019, 03:33:55 pm »
Thanks for the kind words.
PCBs are all made by PCBway in China. I kept the sizes to below 100x100mm so they are $5 for 10. That way you can make up an entire amp for very little money! I've a few left over which I'll be wanting to get rid of soon.
Offline MakerDP
« Reply #3 on: March 16, 2019, 07:05:29 pm »
Nice work Tristanc!
Someday I will build an October... some day...
