September 17, 2026, 02:06:30 pm
Hoffman Amps Forum image Author Topic: filter choke resonating capacitor?  (Read 5510 times)
Offline ALBATROS1234
« on: April 02, 2019, 05:12:28 pm »
i picked up a 1946 stromberg carlson 1121 pf console stereo and its just too cool and must be properly restored. when making a list of parts to order i came across what they call on the parts list a "filter choke resonating capacitor" it has a value of 1uf @ 200v in the chassis it is a huge paper and wax job so its gotta go since this thing is 73 years old. i did some digging and it seems this is and old school way of filtering whereas a smaller choke than normal could be made to resonate at a certain frequency to improve filtering when a certain size cap it connected in parallel with the choke. my main question is what type of cap do i used. it doesnt seem to need to be polarized as it spans between  the first 2 main filter caps where a choke can normally be seen but parallel to this choke( see below  schematic capcitor #13) i want to replace this cap because i got a feeling it is a crucial part of this design and will hum if i dont put the correct type and value of cap in this place. thanks for looking gents
Re: filter choke resonating capacitor?
« Reply #1 on: April 02, 2019, 05:24:05 pm »
Any 1µF @ 200v will work.
« Reply #2 on: April 02, 2019, 05:29:07 pm »
thats what i thought just wanted to see if it needed to be a certain type cap, thanks slucky.
Offline trobbins
    • Tim's projects and info
« Reply #3 on: April 05, 2019, 11:55:31 pm »
Perhaps check with PSUD2 if the choke voltage can reverse polarity.  I'd use a poly cap for safety and possibly ripple current. lt may be tricky to work out the nominal resonant frequency as you need to measure the choke inductance at the operating voltage and dc current.   The aim is to significantly lower 100/120 Hz ripple harmonic.
« Reply #4 on: April 08, 2019, 12:19:01 pm »
I ordered a Dayton polypropylene cap. I used the value from the schematic because it was available online for free as well as a service manual for the webcor record changer. That plus the cap can and a few other odds and ends should be at my house when i get off work .Thanks for the reply.
