September 17, 2026, 09:22:33 pm
Hoffman Amps Forum image Author Topic: PHOENIX VOCAL PA AMP  (Read 4193 times)
« on: April 07, 2019, 04:12:39 am »
Hi guys, Another local built amp from the late 60's.
The only mod to the preamp is on channel 3.
The OT has a 4ohm tap so dropping two power valves and using an 8ohm load will do the trick.
I'm not sure if the feedback resistor needs to be tweaked, sounds good as is.
I've done most of the recap just waiting on a delivery.
