September 16, 2026, 06:33:38 pm
Hoffman Amps Forum image Author Topic: heptode amps  (Read 10367 times)
Offline theanalogkid
heptode amps
« on: April 10, 2019, 06:51:06 pm »
Has anyone ever encountered this amp? I think it was in the 2nd edition of glass audio magazine. It uses an ECH81 for a preamp/phase inverter. It's variable from SE to PP. I've included the main schematic and the whole article as a PDF.
Re: heptode amps
« Reply #1 on: April 11, 2019, 09:22:50 am »
Very cool concept!
Re: heptode amps
« Reply #2 on: April 11, 2019, 08:17:21 pm »
Hard to believe 10K under the power tube cathodes.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: heptode amps
« Reply #3 on: April 11, 2019, 08:22:26 pm »
Not expected values! Would you explain please?
https://soundcloud.com/ukiuki
Re: heptode amps
« Reply #4 on: April 11, 2019, 08:23:13 pm »
hellofa cathode followers with nothing following?  :BangHead:
10R Is probably what is wanted. si?
Offline VMS
Re: heptode amps
« Reply #5 on: April 12, 2019, 03:52:24 am »
I'm guessing that ECH81 could also be used for mixing two channels or feeding dry signal to one grid and reverb signal to the more sensitive grid.
Re: heptode amps
« Reply #6 on: April 12, 2019, 04:15:01 am »
There is something build that way
one old Australian amp
at home I've a scheme
EDIT: OK, not exactly what you are saying
Here are the Playmaster 102 and 103 schematics the 6BE6 is used to "mix" signal and vibrato
« Last Edit: April 12, 2019, 01:45:39 pm by kagliostro »
Offline VMS
Re: heptode amps
« Reply #7 on: April 13, 2019, 05:21:15 am »
Yes, not quite the same but interesting looking circuits, thanks for sharing
Re: heptode amps
« Reply #8 on: April 13, 2019, 09:31:06 am »
I would like a more in depth analysis of the circuit. Or at least a more in depth analysis the in the authors article. I understand a lot of the amp, but still have questions. The 10k cathode resistor on the power tubes. For example. I've never heard of such a high value. Your supposed to be able to use any pentodes in the circuit, but I don't fully understand the math to get the right values for other tube types. The power supply shows 460 volts for the B+ and the main schematic shows 480 volts for the B+. Typo? Any and all information is appreciated.
Offline VMS
Re: heptode amps
« Reply #9 on: April 13, 2019, 10:21:51 am »
As PRR and dummyload pointed, R14 and R15 resistors are 10R resistors and not 10K resistors.
Article says:
set the bias to 40mA (0.4V over R14 and R15)
