September 16, 2026, 12:04:16 am
Hoffman Amps Forum image Author Topic: Vibro Champ with harmonic tremolo?  (Read 9735 times)
Offline Opry Audio
  • tube amp bitch
« on: April 28, 2019, 11:31:39 am »
Yo! I'm really looking for an excuse to build something simple with harmonic trem, basically what's in a brownface showman IMO the best sounding harmonic trem circuit I've heard. Is it worth doing a vibro champ build with harmonic trem and an extra gain stage from the unused triode? I haven't really loved any vibro champs that I've played, but I'd like to do something crazy with it. Maybe doing a 5w with harmonic trem and a separate line-out so it can be used as a preamp in the front of a louder amp. Maybe with a 15" extension cabinet? Does this sound super cool or super lame? Would harmonic trem even do well with a cathodyne PI and a SE output?
Re: Vibro Champ with harmonic tremolo?
« Reply #1 on: April 28, 2019, 12:28:36 pm »
Maybe you would like a Revibe unit that can be used with any amp?
Offline Opry Audio
  • tube amp bitch
« Reply #2 on: April 28, 2019, 01:01:12 pm »
I've done a lot of research on the revibe and would really like to build one! I actually have a PT and reverb TR for a 6G15 I was thinking about building and just got them because i could get the transformers really cheaply. Do I need something more powerful for the revibe? Is there any potential to add a tube preamp aspect to a build like that? Sort of a feature aside from the reverb and trem but that would work well in the circuit?
« Reply #3 on: April 28, 2019, 02:04:02 pm »
The Revibe is a challenging project. You'll be in the deep end of the pool, especially if you are thinking of adding preamps and stuff. The 6G15 PT is adequately rated for a 6G15, but is slightly under rated for a Revibe. It will supply power to a Revibe unit, just barely. You will want a bigger PT if you add more tubes.
« Reply #4 on: April 28, 2019, 02:09:08 pm »
I was just typing....
Isn't v2 basically the "pre"?  Taking guitar to 6V6 level.  I would think tubes are better spent AFTER the re-vibe  :dontknow:
Offline Opry Audio
  • tube amp bitch
« Reply #5 on: April 28, 2019, 02:11:37 pm »
What PT would you suggest?
« Reply #6 on: April 28, 2019, 02:21:02 pm »
Depends on how many additional tubes. If you will tally up the amount of filament current needed for your circuit, I'll be in a better position to suggest a PT.
Offline Opry Audio
  • tube amp bitch
« Reply #7 on: April 29, 2019, 09:44:33 am »
I would be looking to do a 5 triode harmonic trem, so I guess 3 tubes for the trem itself. 4 preamp tubes and a 6V6. I like how the Weber revibe sounds a lot, I would like to know what folks think of the hoffman. I would probably construct the layout P2P
I’ve heard of some reverb units designed with 2 tanks that humbuck each other? Anyone have info on this? Or some examples?
« Reply #8 on: April 29, 2019, 09:48:42 am »
I'm not familiar with that idea. Could you post some links to such info?
Offline st
« Reply #9 on: April 29, 2019, 10:13:51 am »
I hate to draw attention away from Opry's question, but here I go anyway. While not containing schematics or authoritative build reports, the following is a discussion on humbucking reverb thanks I once bookmarked.
https://groupdiy.com/index.php?topic=66617.20
« Reply #10 on: April 29, 2019, 10:14:20 am »
I built one early on here and loved it, the guitar guys did also, the downside;
that's what I did, it's a pretty complex circuit on it's own, my lead dress was bad, I got too many gremlins from P2P, most of it became a donor box because of that.  The extra money up front will save your sanity later, fwiw
Offline Opry Audio
  • tube amp bitch
« Reply #11 on: April 29, 2019, 11:28:21 am »
Here is a schematic which I think has an example if I’m not totally confused. There should be noise cancellation in theory if you run the input and output transducers from 2 tanks in series just like a humbucking pickup? It looks like PAIA released a kit with this design. Maybe it’s worth exploring in tube form https://www.paia.com/ProdArticles/hotspuse.htm
Offline Opry Audio
  • tube amp bitch
« Reply #12 on: April 29, 2019, 11:37:47 am »
You don’t feel like there’s any way for it to be done right? Not even in a parallel terminal strip turret board esque layout? I’d think it would make the lead dress neater just connecting whatever component to its desired location.
« Last Edit: April 29, 2019, 11:40:20 am by Opry Audio »
« Reply #13 on: April 29, 2019, 12:18:00 pm »
"....should be mounted in a location that is free of ambient electro-magnetic fields."
So PAiA did not claim any special hum-buck ability. IMHO, it may be mildly more susceptible to electric buzz due to the double-high impedance at the pickup. (Mitigated some by the low impedance recovery amp.)
« Reply #14 on: April 29, 2019, 12:48:30 pm »
NOT my build, but I look at it often, dream of the day I get close  :laugh:
If you can do this in P2P  :worthy1:
end of day, it's your project, done your way
« Reply #15 on: April 30, 2019, 06:25:42 am »
An Herzog ?
https://el34world.com/Forum/index.php?topic=17218.msg172218#msg172218
Ciao
« Last Edit: April 30, 2019, 06:36:27 am by kagliostro »
