September 15, 2026, 08:33:40 am
Hoffman Amps Forum image Author Topic: Silvertone 1481 mods  (Read 13669 times)
Offline galaxiex
« on: May 05, 2019, 12:26:59 pm »
So I acquired this 1481 some time ago...
A little ratty looking but works ok...
If it ain't broke, I'll fix it until it is.
Offline galaxiex
Re: Silvertone 1481 mods
« Reply #1 on: May 05, 2019, 12:31:21 pm »
Original baffle is rough...
Original speaker needs a re-cone...
« Reply #2 on: May 05, 2019, 12:34:10 pm »
How do you want it to sound different then it does?   I say this respectfully ……… you've sort of posted something like
"I have an amp.  I want it to sound different then it does.  Please help."
Possible mods might be change values of plate/resistor ratio ……….. OR add cathode caps.
Offline galaxiex
« Reply #3 on: May 05, 2019, 12:35:58 pm »
Thanks, not done posting... mods already made... more to come... :)
This is to document the mods I made.  :icon_biggrin:
« Last Edit: May 05, 2019, 12:44:10 pm by galaxiex »
Offline galaxiex
« Reply #4 on: May 05, 2019, 12:37:38 pm »
First mod... a new speaker and baffle...
Offline galaxiex
« Reply #5 on: May 05, 2019, 12:38:30 pm »
I found some schematics online, but they all have the same mistake.
The 220K grid leak resistor is in the wrong place.
Offline galaxiex
« Reply #6 on: May 05, 2019, 12:39:16 pm »
Redraw of the schematic...
Offline galaxiex
« Reply #7 on: May 05, 2019, 12:40:10 pm »
Inside is fairly clean...
Offline galaxiex
« Reply #8 on: May 05, 2019, 12:40:52 pm »
Added a 3 wire grounded power cord and clipped the death cap...
Offline galaxiex
« Reply #9 on: May 05, 2019, 12:41:43 pm »
Unhooked the original cap can and added 3 new electro caps for the power supply...
Also added a speaker jack...
Offline galaxiex
« Reply #10 on: May 05, 2019, 12:42:29 pm »
After much experimenting I ended up with these circuit mods...
Grid stoppers R3, R7, R11
Bypass caps C2, C5
Compare to original schematic redraw above...
For reference:
B+ 275V
Screen 260V
Pre 160V
HTR 6.4 AC
« Last Edit: May 05, 2019, 01:39:58 pm by galaxiex »
Offline galaxiex
« Reply #11 on: May 05, 2019, 12:43:23 pm »
The mods turned this amp into a distortion monster...
Maybe not everyone's cup of tea, but I like it.  :icon_biggrin:
The grid stoppers are ABSOLUTELY necessary, as the amp will squeal and oscillate without them.
Sorry no sound clips, I have no way to record it.
Pic of the mods...
« Last Edit: May 05, 2019, 12:45:25 pm by galaxiex »
Offline galaxiex
« Reply #12 on: May 05, 2019, 12:45:54 pm »
Now I'm looking for an 8 ohm output transformer as the original died, so I installed a Champ replacement TX that is 3.2 ohm.
The Warehouse speaker is a 4 ohm, but I'd like to be able to plug this into an 8 ohm cab.
Also 8 ohms would give me more options for the in cab speaker.
Any suggestions for an 8 ohm output Tx?
Thanks!
« Reply #13 on: May 05, 2019, 12:50:56 pm »
Look at the Mojo771. Just click the transformers link below this message.
Offline galaxiex
« Reply #14 on: May 05, 2019, 12:53:30 pm »
Thanks!
That looks like just the thing!  :icon_biggrin:
Offline galaxiex
« Reply #15 on: May 05, 2019, 01:05:55 pm »
Tx ordered, now the wait....
Offline Papa Jim
« Reply #16 on: May 05, 2019, 02:09:42 pm »
Wow. That was fast. My heads still spinning.  :laugh:
« Reply #17 on: May 05, 2019, 05:06:19 pm »
While you're waiting go ahead and heat up your soldering iron.  :icon_biggrin:
Offline VMS
« Reply #18 on: May 05, 2019, 05:37:19 pm »
Nicely done!
Are the pots linear or log and how do you like that simple tone control?
Offline galaxiex
« Reply #19 on: May 05, 2019, 08:12:00 pm »
Nicely done!
Thanks!
The vol pot is (I think) linear and the tone is log.
Not 100% sure, I never checked them.
The tone pot works ok, simple hi-cut.
It's effective enough through out it's range. I find 5 or 6 on the dial works well.
You can get good tones at all settings, depends on guitar and pickups (Tele neck, bridge, both).
Roll off guitar volume and ease pick attack and you can coax clean-ish sounds out of it too.  :icon_biggrin:
« Reply #20 on: May 05, 2019, 09:13:55 pm »
I like the way you think ! :thumbsup:
The TS on my last build 1-3 dark to bluezy, 4-7 rock, 8-10 more treble
see guitar for the rest  :icon_biggrin:
« Reply #21 on: May 06, 2019, 04:32:04 pm »
How's the hiss?
The Volume control is out front. So it has full hiss even when turned-down. Some amps do that. Most amps don't. I'm wondering if you notice when you stop playing, or if you care.
Offline galaxiex
« Reply #22 on: May 06, 2019, 08:13:57 pm »
How's the hiss?
A little hissy but actually not bad,
no worse than my 73 Princeton Reverb, and it's pretty quiet.
