September 15, 2026, 08:16:23 am
Hoffman Amps Forum image Author Topic: Using proper choke  (Read 7724 times)
Offline dude
Using proper choke
« on: May 05, 2019, 01:38:04 pm »
Does the type of rectifier used determine the Henries value of a choke used..?  Not finding much info on this. Will I usually find the choke value needed in the rectifier tube data?
thanks,
al
Re: Using proper choke
« Reply #1 on: May 05, 2019, 02:59:02 pm »
Nearly all guitar-amp power supplies are cap-input, so the rectifier isn't facing the choke directly.
Nearly all push-pull amps omit any choke to the OT's B+ feed.
So the choke normally only has to feed screens and preamps. You pick an affordable lump of iron with enough current rating for this load. It has less DC drop for a load and more filtering than a simple resistor. The exact value of inductance is not real critical because if the filtering is insufficient it is much cheaper to use larger caps than a bigger coil.
« Reply #2 on: May 05, 2019, 04:01:14 pm »
The tube charts spec the choke for a choke input circuit.  This is not applicable when the choke is used downstream (after the plate supply node on the B+ rail.)
A R can be used in place of a choke; so why use a choke.  For design criteria, a choke reduces ripple without dropping voltage to the screen under signal conditions. Also, because a choke is a reactive device,  it sounds and feels different from a R.
« Reply #3 on: May 05, 2019, 04:12:29 pm »
SO, what if the choke supplies the preamp only.....
« Reply #4 on: May 05, 2019, 04:37:28 pm »
« Reply #5 on: May 05, 2019, 05:35:21 pm »
Take a 1/4-20 x 3/4" long bolt and wrap 200 turns of #30 magnet wire around it.   :icon_biggrin:
Actually, why would you need a choke with such a light load? It's very easy to obtain almost perfectly smooth dc with just a CRC filter when the load is only a few mils.
« Reply #6 on: May 05, 2019, 05:53:07 pm »
Thanks sluckey,
This many valves in the preamp....
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #7 on: May 05, 2019, 06:44:04 pm »
SE amps need a choke before the OT B+ supply for hum free operation. In all my builds a 5H choke is good, PP or SE. , 12 W or 100W. Chose the mA rating acording to what the circuit is drawing, times 2.
P.S.: call me Alvin.
« Reply #8 on: May 05, 2019, 08:00:54 pm »
I agree, but IF you make a "stiff" PS they can be "worked around", I have 2 11lb-ers
as book ends for now.  You need a CRC with BIG C's before the OT tap, AND a big Ck.
saves money, saves weight, but WILL loose about 20% of the guitar players
Offline dude
« Reply #9 on: May 06, 2019, 09:57:49 am »
So, you're saying a Vibrochamp would benefit from a choke..., less hum? I changed the filament wiring on mine (later BF design) and the hum left.
« Reply #10 on: May 06, 2019, 10:01:38 am »
the choke will help with PS buzz in SE amps. filament string hum is separate noise article.
