September 15, 2026, 06:28:41 am
Hoffman Amps Forum image Author Topic: Power Amp 40-50 Watts with 4 5881s  (Read 4921 times)
Offline mwelch55
« on: May 06, 2019, 02:49:05 pm »
I got a good price on a power transformer with specifications 300-0-300 270ma 5V 3A & 6V 9A.  I was wondering if I could design a power amp with this trasformer so that 4 tungsol 5881 installed will give me around 40-50 watts?
I love the sound of the tungsol 5881 reissue.  The problem with that tube is that you can't put two of them into a normal 50 watt amp because the voltage is too high.  The tungsol 5881 is happier at a lower plate voltage.  With secondary voltage at 300-0-300, I should be able to get around  400vdc. I love the way my previous amp sounds with 2 tungsol 5881s with a 6.6K OT and around 380-400 volts on the plate. In that amp I get around 20-25 watts.  That arrangement is my favorite power amp.
I was hoping to do the same thing only around twice the power and I am hoping to get a similar tone as with 2 5881s.  Does this seem like it will work as I expect it to?
Mike
Re: Power Amp 40-50 Watts with 4 5881s
« Reply #1 on: May 06, 2019, 03:13:59 pm »
Wasn't the first 5F6a 40 Watts on two 5881, around 400V and 4k load?
« Reply #2 on: May 06, 2019, 03:41:03 pm »
schema states 432V. i don't imagine that 32V is going to make or break 5881, even the current production stuff.
« Reply #3 on: May 06, 2019, 05:31:53 pm »
Comments.  I like the idea of 4X 5881's to take advantage of the hi current handling of this PT's HT supply.  Should yield about 35W.  Personally I would drop about 100V with a combination of a bucking tranny + a large (inductive) power resistor.
A 5U4 rectifier should work; and help drop some B+.
The hi current heater supply calls out for creative use of small bottle tubes.
