September 17, 2026, 02:09:20 am
Hoffman Amps Forum image Author Topic: 20 watt/5 watt amps with EL34 or 6L6, how are companies doing that?  (Read 9211 times)
Offline Shack
Subject says it all.....the new Marshall  series and others are doing it.....some others use EL84 or 6V6.........I just want to know what they are doing to get the amps lower watts , and also how the builders make the 5 or 1 watt settings.....can anyone shed light on it for me?
New build problems? Click here.
I searched this string on web and got way more than I wanna read
variable power switching tube amps
Some amp use a VVR, other a control on the cathode of the PI, other has a lower voltage intake on the PS to have low B+, other has a lower power alternative set of the Power Tube, some has circuit able to go from PP to SE, may be also MV or PPIMV
EL34 and 6L6 are not so very different. It is no trick to build an amp which will take either (or both), no change.
If it is big bottles or peanut bottles, there are many ways.
« Last Edit: May 14, 2019, 12:46:31 am by kagliostro »
Offline d95err
I think those 20W EL34 amps simply use a transformer with lower voltage.
For the 5W mode, they probably switch to single-ended operation.
Offline JB
The new Marshall’s are switching power transformer secondary taps.
Traynor dark horse example that uses different tubes for Power section
and also look to this Ampmaker Kit for the B+ switch
« Last Edit: May 14, 2019, 02:20:56 am by kagliostro »
Offline d95err
Does that mean they run with very low preamp voltages (especially in the 5W mode)?
Or do they use a separate preamp winding?
Here you can see how they do it on the Mesa Boogie Lonestar Special
Note the PS section and PA section
« Last Edit: May 14, 2019, 03:04:32 am by kagliostro »
Offline JB
Re: 20 watt/5 watt amps with EL34 or 6L6, how are companies doing that?
« Reply #10 on: May 14, 2019, 01:42:48 pm »
In the Superlead version they're running the preamp on typical Superlead voltages but the PI/PA are lowered in 5W mode.  It's cathode biased and they're running the EL34's at way less than in a real Superlead, even in 20W mode.
Offline Shack
« Reply #11 on: May 16, 2019, 05:51:01 pm »
interesting.....I just see it is a big thing these days to use 30/10/1 watt amps, and wondered how we could accomplish that
Offline Shack
« Reply #12 on: May 16, 2019, 05:53:40 pm »
I think that lower plate voltage gives you lower power with these tubes I belieave......and PP/SE or triode mode gets you lower.....but to design such amp has me boggled
