September 16, 2026, 10:24:35 pm
Hoffman Amps Forum image Author Topic: 1990 Carvin XT-112 part search help  (Read 5274 times)
Offline jgcable
« on: May 17, 2019, 09:41:11 am »
Hello, I have a 1990 Carvin XT112 combo amp. I have owned it and gigged with it since 1991.  At my last show a mic stand banged into one of the sliders on the 5 band EQ and it broke the little board inside of one of the individual sliders.  It happens to be the bass slide  75.  The slider is marked ALPHA B10K.   The problem I am having is locating a replacement because of the dimensions of it.  Nothing I can find online is the correct size.  Dimensions are as follows.... 45mm center to center (screw holes that mount it to the face of the amp), 12mm width, 11mm height, 50mm length, 30mm travel.  It is soldered to a PC board with 4 contacts. They are marked 1,2 and 3,4 and are staggered. I thought it would be an easy component to locate. Nope.  I tried everywhere online.  Nothing has these dimensions.  Can someone point me in the right direction? Thanks... John
Offline 2deaf
  • Now too deaf for 100 watts
Re: 1990 Carvin XT-112 part search help
« Reply #1 on: May 17, 2019, 11:25:52 pm »
What country are you in?
« Reply #2 on: May 18, 2019, 01:15:16 am »
post a pic of your part. i may have something that will work.
Offline ToneDream
« Reply #3 on: June 17, 2019, 12:50:31 pm »
I'm pretty sure I have. I used to import Carvin to Sweden..
