September 17, 2026, 02:55:15 am
Hoffman Amps Forum image Author Topic: DIY Marantz 7 Motorboating  (Read 7476 times)
« on: May 21, 2019, 12:58:01 pm »
Schematic attached.  120Hz motorboating only on phono stage AND only when turntable is powered off, but preamp and amp still on.  2 chassis build with power supply seperate.  I have not installed a volume pot or step attenuator.  A similar build can be found here http://www.preservationsound.com/?p=3187
Of course, I have DC filiments, which is the only change I have made to the entire build.  I am using an Actual Marantz 7C for my layout guide, but I do have a seperate chassis housing the Power Supply.  Voltages all check to schematic within reason.
The most confusing to me is when I provide a signal with the same voltage maximum I receive from 3 different turntables  (moving magnet, no moving coil), scope reads better than I expected.  It is only motorboating when anything is connected to the inputs of the phono stage and powered off.  If I turn off my signal generator, but leave it connected.  Motorboat yes.  Unplug and stabilizes.
Also, I still need to order a stereo volume control for the build.  What is the best to use in this instance, a stepped attenuator such as an ALPS?  I guess it should be a 500KA stereo, but I have never used a 500Ka for Hifi, only 100K.  If someone knows, and I know some of you do, please let me know.  I have not ordered this simply because I want to use one with a remote receiver.
My main question I guess is could using 2 resistors, 470k temporarely in place of the 500Ka pot cause this?  Suggestions welcome.  Thanks!
Re: DIY Marantz 7 Motorboating
« Reply #1 on: May 21, 2019, 01:28:18 pm »
isolated ground for your "input" device, I know that should be 60hz
the Kit pcb M7 I have used 12.6 for fil, it hummed, way less than guitar, but way more than audio.  I converted to DC, took like 10,000uF 4 stage RC just to get it where I was happy-ish.
you need something pretty sensitive, or good intuitive - which you have, try measuring VDC ground in to ground signal WITHOUT the signal inputted, so your meter is measuring between the 2 disconnected devices
« Reply #2 on: May 21, 2019, 01:59:27 pm »
I understand where you are going.  Will do.  I used all MF resistors with all being double the schematic wattage, but stayed sane with caps.  I used Solen which I find to be quite nice for the cost.  Requlated 6.3 VDC filiments and isolated the phono section using a copper shield. With everything running it sounds great and really no floor noise to speak of.
Usually, when I get something going on like this I get tunnel vision simply because I wouldn't have intentionally wired anything wrong, but I can assure you I did something.  Maybe I connected the hip bone to neck bone. :laugh:   I had read where this preamp did not get very good reviews.  Then I listened to one in very nice shape that had been rebuilt completely and to me it sounds like music should.  He loaned me a parts preamp, which is still really complete.  It needs servicing, but a great build guide.
The one I built has less floor noise than his original, but he has carbon comp mojo and AC filiments.  I can assure you carbon comp resistors lose all their mojo as soon as I solder one in place. :l2:   Ed the Mojo Killer.  Quit, you are harshing my buzz.
« Reply #3 on: May 21, 2019, 02:41:22 pm »
You'll find it, hum sucks, my tube transistor hybrid looked soooo pretty but hummed almost enough not to pass guitar standards, I didn't even bother, I just set the tube part aside for an ALL tube audio.
even on the SS I get a low hum (not bothersome) with NOTHING on the input, goes away with signal, I'm ASSUMING it's because the input is "open".
The hum is still there with a "floating" input, battery powered music, OR turntable straight from needle, plug in a charger, or set turntable to line out and humbegone
« Reply #4 on: May 21, 2019, 08:09:54 pm »
> 120Hz motorboating
Motoboating is usually few-Hz.
120Hz is simple power supply buzz.
Turntable power status should hardly matter (slight 60Hz hum when motor is powered). I suspect a wiring flaw.
