September 16, 2026, 06:19:49 pm
Hoffman Amps Forum image Author Topic: Single Ended Dual Channel Negative Feedback  (Read 4368 times)
Offline mwelch55
« on: May 23, 2019, 12:48:28 pm »
I am almost finished building a single ended dual channel amp.  The amp has two completely separate preamps that doesn't share any of the same circuitry.  I switch between the two using relays.
My question is how to connect the negative feedback?  Can they both get their negative feedback from the same tap or separate taps?  How is this usually accomplished?
Mike
Re: Single Ended Dual Channel Negative Feedback
« Reply #1 on: May 23, 2019, 03:23:37 pm »
NFB is usually a power amp function. It's usual to only have one power amp so there's only one NFB loop. If you have something unusual, show us a schematic please.
« Reply #2 on: May 23, 2019, 03:26:18 pm »
Ditto to a schematic.  In the typical guitar SE Power Amp, NFB is usually fed to the preamp tube that drives the Power Tube(s).  So I think the 2 preamps should drive that last small bottle tube.
« Last Edit: May 23, 2019, 09:10:11 pm by jjasilli »
