September 16, 2026, 12:44:21 am
Hoffman Amps Forum image Author Topic: Valco Model 1215 Professional w/220M Ohn Resistor???  (Read 5825 times)
Offline TubeJunkie
« on: May 26, 2019, 06:13:45 pm »
Okay, so I've been looking at some interesting vintage amps for building, and came across this Valco Model 1215 Professional.  I was going over the schematic looking at what I might have and what I would need, when I found what looks like a reference to a 220M Ohm resistor.  Am I reading this wrong, and if not, why a 220M Ohm resistor?  I looked on-line, and found some, and they're only about $4.00 each, so no big deal, but 220M Ohm?  I've attached a couple of pics for your perusal . . . so does anyone have any insight on this?    :dontknow:
Thanks.
« Last Edit: May 26, 2019, 06:18:22 pm by TubeJunkie »
Re: Valco Model 1215 Professional w/220M Ohn Resistor???
« Reply #1 on: May 26, 2019, 06:59:34 pm »
It says this circuit may not be changed by service technicians  :icon_biggrin:
I "think" it's a floating paraphrase with NFB, other than that, if it worked then  :dontknow:
« Reply #2 on: May 26, 2019, 07:57:21 pm »
It's surely 220K.
At first I thought you found a very old plan. Through WWII, some shops wrote "M" where we would write "K". It's good Roman Numerals.
However *this* plan has K everywhere else I would expect K, "MEG" where Meg makes sense. So I think the draftsman got distracted or confused right there.
« Reply #3 on: May 26, 2019, 08:04:32 pm »
It's 220K. Back then M was used for 1000 (like the Roman Numeral M). MEG was used for million. This schematic appears to be from a time when K was replacing M. Probably caused some confusion back then too.  :icon_biggrin:
« Reply #4 on: May 26, 2019, 08:21:09 pm »
he also lists M as Meg in the TS, I think after lunch he's in a creative frame of mind  :icon_biggrin:
« Reply #5 on: May 26, 2019, 08:37:13 pm »
This guy is really messed up. He has two 500K pots and two 1/2 MEG pots.   :l2:
« Reply #6 on: May 27, 2019, 10:00:49 am »
looking at the text, I make him to be left handed, and until proven otherwise, a good sketch artist, so work is secondary  :icon_biggrin:
Offline Tony Bones
  • Thread Killer
« Reply #7 on: May 27, 2019, 11:58:33 am »
That's a lower case m. It's a 220 milliohm resistor.  :l2:
It was funnier in my head.
« Reply #8 on: May 27, 2019, 12:10:31 pm »
Here's a much better view of the confusion...  :icon_biggrin:
     https://el34world.com/charts/Schematics/files/Valco/Valco_valco_1215.pdf
« Reply #9 on: May 27, 2019, 02:27:02 pm »
yup! I always crack myself up  :laugh:
I think there's a ghost in the good view one  :laugh:
Offline TubeJunkie
« Reply #10 on: May 27, 2019, 02:51:21 pm »
I think it was two guys working on it, or maybe the guy from MIB . . .   :d3:
As noted before, there's both 500k and 1/2Meg, and the resistor in question is listed not only as 220M, but also as a 1/2V resistor.
After looking at a few other Valco schematics, and reading the above, I'm going to go with a 220k resistor.
« Last Edit: May 27, 2019, 03:01:29 pm by TubeJunkie »
