September 15, 2026, 10:04:45 pm
Hoffman Amps Forum image Author Topic: Bias measurement with bypass caps  (Read 4165 times)
Offline kenny1547
« on: May 27, 2019, 10:52:58 pm »
Hey guys!
I googled for days and just cant really find anything, so i thought i might ask here...
Is there a difference in how i would go about measuring bias with a cathode bypass cap on the power tube(s) if an amp is cathode biased? Since it can have more gain that way or rather changes how the tube operates, shouldnt it affect the power tube bias?
Until now i just measured bias with the voltage drop across the cathode resistor, but was never really sure about if the cathode bypass cap changes anything and cant seem to find an answer anywhere
Offline 2deaf
  • Now too deaf for 100 watts
Re: Bias measurement with bypass caps
« Reply #1 on: May 27, 2019, 11:13:57 pm »
The bypass cap doesn't pass DC, so the idle current is the same with or without that cap.  Don't believe me?  Take the cap off and see if anything changes.
Offline kenny1547
« Reply #2 on: May 28, 2019, 02:12:17 am »
No id definitely believe you! I just wasnt sure, thought that it might be more stress for the tube since it operates in an altered way, thanks for clarifying!
