September 15, 2026, 10:00:38 am
Hoffman Amps Forum image Author Topic: Transformer Voltage Question  (Read 5442 times)
Offline shark38j
« on: May 29, 2019, 02:48:10 pm »
I am working on a project with a Classic Tone #40-18016 power transformer.  This is my first amp project and I expected the rectified voltage to be around ~450V DC.  It seems to be much higher.  As I bring it up on the Variac I reach 400V around 50V AC from mains.  Am I missing something?  I have the two red leads hooked to the bridge rectifier and the center tap floating.  Any information would really be appreciated.
Measured Voltages
Voltage from Variac: 13.4V AC
Voltage out of Transformer: 78V AC
Rectified Voltage: 110V DC
Marc
« Last Edit: May 29, 2019, 02:50:31 pm by shark38j »
Offline davidwpack
    • My music on reverbnation
Re: Transformer Voltage Question
« Reply #1 on: May 29, 2019, 02:52:53 pm »
Are All your tubes in? If not the voltage will be higher.
Offline shark38j
« Reply #2 on: May 29, 2019, 02:54:50 pm »
Yes tubes are in and I have verified plate voltages
« Reply #3 on: May 29, 2019, 02:58:00 pm »
Measured Voltages
Marc
That transformer will give you in excess of 900V B+ using a bridge rectifier. It was not meant to be used with a bridge. YOU MUST USE A CONVENTIONAL TWO DIODE RECTIFIER WITH THAT PT!
Offline shark38j
« Reply #4 on: May 29, 2019, 03:05:29 pm »
Ok, my understanding was that 330v - 0 - 330V meant that I would get +330V to -330V from it, 660V P-P.  Your saying that I will get a peak of 660V from it, which is about what I'm getting.  Is there a way to use the center tap to cut it in half?
« Last Edit: May 29, 2019, 03:07:51 pm by shark38j »
« Reply #5 on: May 29, 2019, 03:09:06 pm »
Sure. Disconnect the negative terminal of the bridge from ground. LET THE NEGATIVE TERMINAL FLOAT. Then connect the transformer centertap to chassis ground.
Bring it up on a variac and the voltages will be more what you expect.
« Reply #6 on: May 30, 2019, 11:18:15 am »
Everything working now???
