September 15, 2026, 04:18:50 am
Hoffman Amps Forum image Author Topic: HT supply  (Read 6725 times)
Offline isaac_teller
HT supply
« on: June 01, 2019, 11:21:25 am »
Re: HT supply
« Reply #1 on: June 01, 2019, 12:13:54 pm »
Output Voltage: +45~390V continuously adjustable (default output ±50V)
 Output Current: 0.2A Max(with input, output pressure related,the higher the output voltage, output current is smaller)
This statement alone would save me $5  :icon_biggrin:
you "max" current guessing happens around 50vdc, by the time you get to some useful vdc for tubes there might be enough to power a 12XX7, You still need a filament tranny.
anytime I see specs talking things like "output pressure" I just move on down the line
Re: HT supply
« Reply #2 on: June 01, 2019, 03:24:11 pm »
This has also a heater exit (max 3A) but B+ is rated max 60mA (output voltage is from 150V to 420V) and I don't think they are available at max Hig Voltage output
it will be good for small amp or preamp
https://www.ebay.it/itm/DC-12V-to-150V-420V-DC-High-Voltage-Power-PSU-Board-f-Tube-amp-Preamp-Filament/173034019336?hash=item2849a19a08:g:n~IAAOSw4qxap6GE
The Step Up you posted
https://www.ebay.com/itm/DC-DC-8-32V-to-45-390V-High-Voltage-Boost-Converter-ZVS-Step-up-Booster-Module/322374615632?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
seems to be able to give around 100mA @ 390V (40W max .... OK, peaks of 70W are allowed, but 40W max)
« Last Edit: June 01, 2019, 03:35:08 pm by kagliostro »
Offline silverfox
Re: HT supply
« Reply #3 on: June 01, 2019, 06:10:34 pm »
That doesn't look like 40 watts. Also, is this something recommended for audio? When I've suggested something like this in the past there was the caveat- It may generate a lot of noise.
silverfox.
Re: HT supply
« Reply #4 on: June 01, 2019, 06:44:39 pm »
FWIW, For the price, if you like to tinker and play with electronics as a hobby, there WILL be a use down the road if it can't do tubes.  The switching is at 75khz (IIRC?) which shouldn't bother tubes, but from my experience, any time I get an amp near a poorly made switching supply, I get noise in my otherwise quiet amp
Offline silverfox
Re: HT supply
« Reply #5 on: June 01, 2019, 09:36:25 pm »
75 khz could probably be filtered since it's so far above the audio range, and it could be put in a properly cooled Dog House.
silverfox.
Offline Tony Bones
  • Thread Killer
Re: HT supply
« Reply #6 on: June 01, 2019, 09:54:00 pm »
The doghouse is important. Filtering the supply itself is not too hard, but switchers tend to radiate a lot of EMI at the switching frequency and harmonics. You might get away with just putting something like this at the far end of the chassis, but putting it inside a grounded box helps.
Offline silverfox
Re: HT supply
« Reply #7 on: June 01, 2019, 11:00:13 pm »
Another possibility might be, raising the amp ground 5 or 10 ohms above inverter and earth ground. Recently saw a circuit that did that.
silverfox.
Re: HT supply
« Reply #8 on: June 02, 2019, 11:49:05 am »
..... is this something recommended for audio?
So they say in the description
DC12V boost, with a set of filament and a set of high voltage, two sets of voltage adjustable
Input voltage: 12VDC
Output high voltage: 150V-420VDC, 1.25V-12V DC filament voltage regulator is adjustable
Due to the use of high-frequency switch, no effect on the audio, signal to noise ratio is very high.
The max of the current of the High-voltage output is : 60MA
The max of current of filament output is:  3A
The image is referred to the first link, not those you posted, the circuit on the image spec say 60mA
I told
