September 15, 2026, 11:02:40 am
Hoffman Amps Forum image Author Topic: DC Elevated Filaments to Relay Power Supply  (Read 4173 times)
Offline stevensloane
« on: June 07, 2019, 07:52:48 am »
Can I DC elevated filaments to power the relay power supply?
Re: DC Elevated Filaments to Relay Power Supply
« Reply #1 on: June 07, 2019, 09:44:30 am »
I don't see elevated heaters or relays in the schematic your posted  :dontknow:
there's a good read for relays, make note of power hookup at the very end
http://el34world.com/projects/relay_switch.htm
« Reply #2 on: June 07, 2019, 09:56:42 am »
There is no relay in the schematic. I’m using one of Doug’s relays and power supplies. There a DC elevated heater supply in the schematic. Follow the center tap for the heaters. What I am asking is it ok to hook up the heaters on this schematic to Doug’s power supply.
« Last Edit: June 07, 2019, 10:09:28 am by stevensloane »
« Reply #3 on: June 07, 2019, 10:19:03 am »
Should be OK ***IF*** you float Doug's power supply, ie, don't connect the 5V common (ground) to chassis ground. This also means use isolated jacks for footswitches.
