September 16, 2026, 10:22:57 am
Hoffman Amps Forum image Author Topic: UL mode  (Read 4697 times)
Offline isaac_teller
UL mode
« on: June 12, 2019, 09:55:16 am »
Hello. Is there a more sophisticated way to switch an amp from pentode mode to UL mode other than a regular toggle switch? Thank you.
Re: UL mode
« Reply #1 on: June 12, 2019, 10:21:19 am »
absolutely, I can probably get a 10 part count circuit but we usually strive for KISS  :icon_biggrin:
use the switch for experimenting, you'll probably find what most have, it's either hardwired UL or Pentode, no real advantage in otherwords
Re: UL mode
« Reply #2 on: June 12, 2019, 10:25:48 am »
Bear in mind there are massive back emf voltage spikes on the plates of overdriven power tubes; so depending on the HT voltage, maybe 2 to 4kV between the terminals of the poles of a dpdt ul-pentode switch. I don’t think it’s good practice to introduce switches / anything there, just use direct tidy wiring, use a switch in the design phase only preferably.
« Last Edit: June 12, 2019, 10:30:07 am by pdf64 »
Re: UL mode
« Reply #3 on: June 12, 2019, 10:42:02 am »
Sure. Use an extra set of sockets. Wire one set for pentode and wire the other set for U/L. Swap tubes back and forth.
Or, you could wire two sets as above but put two sets of tubes in. Use a SPDT switch to connect the cathodes of only one set to ground.
I've never tried either of these Rube ideas, so proceed with caution.   :icon_biggrin:
Re: UL mode
« Reply #4 on: June 12, 2019, 11:05:11 am »
Thank you everyone!
