September 17, 2026, 02:07:21 am
Hoffman Amps Forum image Author Topic: Mating 4 6l6gc to the right ot  (Read 8202 times)
Offline Cubed
« on: June 15, 2019, 12:21:34 pm »
Hello, I'm starting to understand the data sheet and I see there's info for effective load resistance for 1 and 2 tubes in a single ended amp and the elr for a push pull amp with 2 tubes.
My question is how do I figure out the elr for 4 6l6gc in a push pull setting?
I would think this would be a good ot for it (from what I read in the description) but I can't get the math right before I pull the trigger
http://www.classictone.net/40-18013.html
Offline Tony Bones
  • Thread Killer
Re: Mating 4 6l6gc to the right ot
« Reply #1 on: June 15, 2019, 12:34:35 pm »
Use 1/2 the load you would use for a pair of 6L6 under the same operating conditions.
That Classictone OT will work fine assuming you're running the tubes around the same voltages and currents as a BF Twin.
Offline Cubed
« Reply #2 on: June 15, 2019, 01:07:19 pm »
Thanks for the details!
I will look into the bf twin specs then. I wanted to follow what the data sheet said but I will look further into design and specs as there's much more I can learn.
Offline Cubed
« Reply #3 on: June 15, 2019, 02:47:09 pm »
It seems I put the carriage in front of the horse.
It seems I the effective load resistance can be adjusted with different voltages and or current.
I'm using this data sheet but how do I figure out what requirements I need to use to get a certain elr?
https://frank.pocnet.net/sheets/127/6/6L6GC.pdf
I do apologize for the dumb questions, seems I'm biting of more then I can handle.  :w2:
Offline Tony Bones
  • Thread Killer
« Reply #4 on: June 15, 2019, 03:30:35 pm »
Seems likely.  :icon_biggrin:
There's an entire spectrum of things that will work.
Perhaps you should start by identifying some amps that you might like to emulate, then study those amps a little.
Deciding from the start that you want to use 4x6L6 is a little like deciding you want to find a cookie recipe that uses 1/2 stick of butter... unless you have a lot of experience cooking and have a good reason for choosing that exact amount of butter.
Don't tell me you happen to have four 6L6 tubes and want to figure out how to use them. I happen to have 1/2 stick of butter. So what?
Offline vampwizzard
    • Walbertedwards.com
« Reply #5 on: June 15, 2019, 03:50:34 pm »
What you do with 4 6l6's and a half stick of butter is none of my business.
Offline Cubed
« Reply #6 on: June 15, 2019, 04:06:22 pm »
Thanks again.
I really want to build a 100 watt amp. I'm just sold on the idea. I leaned about elr and winding ratio on the ot so a lot of things just started to make some sense on the power amp section.
But when diving further I couldn't figure out how they got there with certain a certain ot.
I will check out other amps though.
And no, I didn't have 4 tubes laying around, I like the sound of 6l6gc tubes from experience and wanted to go and "come up" with a design with them while also understanding how I got there.
« Reply #7 on: June 15, 2019, 07:29:00 pm »
100W with 4 x 6L6s? Sounds like you want a 100W twin reverb, quad reverb, super six reverb, or dual showman reverb or similar. So get a PT, choke and OT for one of those. The iron for those amps from 1973 onwards is identical - see attached schematic. (But do yourself a favour and don't build it with the crappy silverface MV circuit. And most guys 'blackface' the bias circuitry)
Offline Tony Bones
  • Thread Killer
« Reply #8 on: June 16, 2019, 09:33:40 am »
Thanks again.
In general, when paralleling tubes cut the load in half. So, if you have a SE amp with one output tube and an 8K load, but you want to run two tubes n parallel, then use 8K/2 = 4K load.
There's a column in the 6L6 data sheet showing 2x6L6 at 450V Plate and 400V screen with a 5.6K load, so 4x6L6 should run at 2.8K. The Fender amps that Tubeswell posted run 4x6L6 at around 450V on both plates an screen with a 2.1K load and it seem to work very well. (That's the Classictone OT you linked to.)
There's a fairly wide range of loads that will work. Changing it will affect the sound, but it's hard to say how without trying it. A this point I wouldn't worry too much about this detail.
« Reply #9 on: June 16, 2019, 11:59:02 am »
IMHO this is the best advice.  I.e., plagiarize iron selection, and power supply specs, from a known 4X 6L6 amp that you like.
N.B.: the tube charts show plate loads affected by factors other than voltage:  such as THD; and rather low screen voltages which are not ordinarily used in guitar amps (except for UL).  I.e., in guitar amps idle screen voltage usually equals (or slightly exceeds), plate voltage @ idle.  Hence, guitar amp plate loads will deviate from the tube charts. Knowing the math is good, but not sufficient.  You are condemning yourself to repeat Leo's R&D, usually through years of trial and error.
« Reply #10 on: June 16, 2019, 08:45:48 pm »
Then what jjasilli said. Leo Fender worked it out when Dick Dale was a kid. While his way is not the "only" way, you also want to avoid custom transformers and extended smoke-tests. You buy standard replacement iron for the Fender 80W-100W amps and copy most of the power section from Fender plans.
Offline st
« Reply #11 on: June 17, 2019, 09:52:14 am »
I agree more or less. Doing the math and experimenting is half the fun, if you know what your doing.
You now have two options: go with a known working design, or figure it out yourself. Choose the sensible option in view of your experience.
Offline Cubed
« Reply #12 on: June 17, 2019, 08:40:47 pm »
Thanks for all the info!
I did want to avoid smoking transformers while trying to come up from scratch but what I read in this thread, forum, and from amp builders, it's not a perfect science and I better off as a beginner learning by building a known amp design.
Thanks guys I appreciate taking your time setting me to the right course.
