September 15, 2026, 10:04:09 pm
Hoffman Amps Forum image Author Topic: Noisy power supply for stomp boxes  (Read 8785 times)
Offline smackoj
« on: June 15, 2019, 06:10:01 pm »
Hello again gents; Like so many other guitar players, I seem to be plagued by noisy stomp pedals. I have done lots of switching around trying to quiet them down and what seems to be the biggest problem is noise from the wall wart 9vdc power supply. I have a couple bench type regulated PSs that have ample filtering but they are designed for loads that draw more current than a few stomp boxes. So I ask this question; will a stout regulated PS that can push 12vdc all day up to 10-12 amps damage a stomp box that is only drawing milliamps?
Thanks amigos   :icon_biggrin:
Re: Noisy power supply for stomp boxes
« Reply #1 on: June 15, 2019, 09:17:07 pm »
no
Offline smackoj
« Reply #2 on: June 16, 2019, 07:40:35 am »
thanks SL
Offline OrganicEffects
« Reply #3 on: June 16, 2019, 10:11:45 am »
You don't mention what you're using, but I've had fantastic experience with 1Spot's powering a couple dozen pedals at once, DIY and commercial, digital and analog. Very quiet.
Offline smackoj
« Reply #4 on: June 16, 2019, 08:39:03 pm »
I appreciate the tip Organic!
« Reply #5 on: June 19, 2019, 10:27:27 am »
10 -12A is OK but overkill especially for portability.  There's lots of quiet expensive & inexpensive pedal supplies available today.
Maybe not OK for some 9V pedals to have a 12V supply.
Over voltage causes excessive current draw, which may exceed the handling capacity of leads or components in the pedal's circuitry.  Let's say a 9V pedal draws 9mA, or .009A.  Per the Power Formula, the pedal is dissipating .081 W.
Per Ohm's Law the pedal is functioning as if it were a 1000 Ohm resistor.  If we increase the voltage to 12V, current draw increases to .012A.  Per the Power Formula, the pedal is now dissipating .144 W, a 56% increase in current, even though the voltage is only 33% more.
Wallwarts have very poor voltage regulation, which can be a problem for pedals.  A typical 9V wallwart may put out 14V unloaded.  If the wallwart is rated for 500mA but is feeding only a 9mA pedal, then the pedal may receive near the full 14V.  This can cause a harmful over-current condition as shown above.
Voltage regulation is good.  It prevents over-voltage; and I think that the process of voltage regulation also compresses noise in the DC power supply.
