September 08, 2026, 03:49:55 pm
Hoffman Amps Forum image Author Topic: circuit suggestion  (Read 5011 times)
Offline Geezer
circuit suggestion
« on: June 18, 2005, 05:25:29 am »
        > circuit suggestion
<< Prev Topic | Next Topic >>
Author  Comment
ernie jr
Junior tube assistant
(3/16/04 8:03 pm)
 circuit suggestion
 i have a power tranny 400-400v 200ma, 5v 4a, 6.3v 5a
and an output tranny 9000 ohm ct, 8 and 16 ohm 50 watt.
any ideas as to a bass guitar circuit i could build? maybe something with 6550's using the o/p taps as 8 and 4 ohm to
bring the primary to about 4500 ohm. the o/p tranny is a stancor "hi fi" tranny with a broad freq range.
thanks for the help
ernie
6G6
(3/16/04 10:16 pm)
 Re: circuit suggestion
 I'd vote for a simple, single channel Fenderish amp.
Perhaps the "normal" channel of an AB 165 with values on the tone stack somewhere between the bass & normal channel.
If the OT has UL taps, you might want to use them for a bass amp.
400-0-400 with full wave SS rectifier will give you about 560V.
In real life that would be less, maybe 540-550 at the plates.
6550 would be fine.
Other choices would be :
KT 88
KT 66
El 34
I'd use 6550 or KT 88.
Don't bias them too hot, there's not a lot of current to work with there.
Another option would be the Sunn S200.
wayneosdias
Senior tube assistant
(3/16/04 10:18 pm)
 have you looked at the svt's w/6550's
wayne
6G6
(3/16/04 10:47 pm)
 Ampeg makes great bass amps, but I was looking at keeping it simple and keeping the current draw down some by only needing one preamp tube and a PI before the output tubes.
Another thought I just had is that there's nothing to prevent you from from adding a midrange pot or even hi-mid and lo-mid.
The Duncan amp tone stack calculator would let you tailor it to suit.
I have a G-K that uses four pots and it's very versital.
I think (off the top of my head) they are at something like
50Hz, 200Hz, 1200Hz and 4000Hz.
If you like that idea, I can find out for sure just where they are. I can say for sure that they work!
If you want another knob there is always the Presence from a Brownface bassman.
I'd bet that is enough to get almost any sound you need with only one channel.
ernie jr
(3/17/04 6:57 am)
 circuit help
 i have bulit a sunn 200s, but it uses ultralinear o/p trans,
the one i have is not. what changes would need to be made to convert the circuit to a non-linear o/p trans.
thanks
ernie
6G6
(3/17/04 9:30 am)
 Re: circuit help
 The ultra linear taps provide the voltage for your screens.
If you look at most Fender schematics, you will see that they use the second filter stage for that.
It's fun to look at a couple of transformers sitting on your bench and try to decide what they want to become part of.
ernie jr
(3/17/04 10:58 am)
 circuit help
 i was thinking maybe a sunn 200s in triode mode, or a hoffman plexi 50 with 6550's
any thoughts
ernie
6G6
(3/17/04 1:32 pm)
 Re: circuit help
 Personally, I've never really liked Marshall type amps much for bass.
If you already have a Sunn S200, you could change it to cathode bias to see if that's what you want, way easier than building another amp.
I'm kinda surprised that no one has suggested some circuit I never thought of. I know there's more options than I've ****d.
wayneosdias
(3/17/04 5:07 pm)
 Re: circuit help
 if your going simple what about a bassman 135 or 200w?
wayne
 Topic Commands
Powered By ezboard® Ver. 7.32
