August 29, 2026, 04:57:40 pm
Hoffman Amps Forum image Author Topic: PT specs  (Read 4077 times)
Offline dude
PT specs
« on: June 30, 2019, 10:01:18 am »
Been reading about PT specs but can’t find info on exactly what determines the overall rating, 160mA, 180mA, 200mA, etc. Big bottles need higher ratings, regarding the PT windings what determines this rating. Is the sum of current draw for each secondary added to determine what rating is needed?
Offline Glenn
Re: PT specs
« Reply #1 on: June 30, 2019, 11:26:42 am »
Try looking at this. Plug in different tube types and preamp tube count to see how the
Current draw changes. Gives a good ballpark on what type a PT is needed per situation
https://thesubjectmatter.com/calcptcurrent.html
Joe
Re: PT specs
« Reply #2 on: June 30, 2019, 12:23:06 pm »
To design a PT is like designing a pickup truck. A 1-ton truck has bigger axles, springs, frame than a 1/2-ton truck. A high-current winding has fatter wire; and for the same voltage, fatter iron to handle the higher power.
If you are asking about what pre-made PT to buy for a given tube(s) and plan: look in the tube-book and find a similar Suggested Condition. Add plate and screen current. Add 10% to cover your small-tubes.
Also: figure out what Popular Brand amp works the same tubes at the same output, and buy the Replacement iron (PT and OT) for that. Couple 6L6GC working hard? That's a 2x6L6 Fender "40W-50W" and the iron is readily available.
On quick-check it gives reasonable values for push-pull. In SE it assumes full Pdiss(max), which is probably fair for many guitar amps, though if planning a "small" amp you might run cooler.
