September 17, 2026, 04:36:32 am
Hoffman Amps Forum image Author Topic: IEC adapter ring for round hole  (Read 8072 times)
Offline choosebronze
« on: July 05, 2019, 10:08:43 pm »
Well, maybe I'm crazy. I like building in plain Hammond boxes. And I like using removable power cords. I was sitting around a couple weeks ago thinking about IEC chassis holes. I can either tediously cut it with a Dremel, or buy an expensive punch. I don't like buying expensive punch. Round holes with a step bit take 10 seconds, but the (minor) problem with mounting the socket in a round hole is the look. So I sketched a little adapter the IEC socket could slide into, and then bolt the whole thing into the chassis. I talked to my brother-in-law who's got a little 3D printer. He did some magic, made a computer file, and printed the thing. He said the cost to him was probably about 50 cents a piece. I don't sell amps. Maybe this doesn't look professional enough for people who do. But for my own use I like it a lot more than a socket in a round hole.
I wanted to share the idea and ask if anyone else has any use for this? I can ask him for the file and post it here, he said anyone with a 3D printer should be able to print it. I think you can even take the file to some stores now and have them print for you (like Kinko's and Staples). Also, if this is a stupid thing to use for some reason, let me know!
I did't have any scrap metal and haven't started my next build yet, but here's an example of it on a scrap piece of 1/4" plywood. The adapter is about 2.5mm thick and I mounted it over a 1 1/8" hole.
Worth noting guys can 3D print metal objects now, too. I don't understand it. But they do it.
« Last Edit: July 05, 2019, 10:17:33 pm by choosebronze »
Re: IEC adapter ring for round hole
« Reply #1 on: July 06, 2019, 11:19:04 am »
I bet if anyone has access to a CNC machine they could make those cutout adaptors out of alum and sell 'em on eBay for $5 a pop, easy. I know I'd happily pay that amount to not muck around filing out the IEC hole.
« Reply #2 on: July 06, 2019, 03:44:57 pm »
https://www.amprepairparts.com/acconnectors.htm
you only need to find the proper round hole punch
This vertical IEC will also be an interesting item to be added to those Doug sells
« Last Edit: July 06, 2019, 03:57:54 pm by kagliostro »
« Reply #3 on: July 06, 2019, 04:49:42 pm »
Brilliant, Franco! Why isn't that socket sold more places!?
You'd think a big store like Mojotone would either sell metal adapters as suggested, or the vertical screw socket, but nada. Strange.
« Reply #4 on: July 06, 2019, 09:17:06 pm »
they'd rather sell you a punched chassis?
