September 17, 2026, 10:38:40 am
Hoffman Amps Forum image Author Topic: Accessory jack Hoffman AB763  (Read 4443 times)
Offline Diverted
« on: July 09, 2019, 12:46:37 pm »
Hi all,
Awhile ago I built a Hoffman AB763 reverb amp. It has a 2/4/8 ohm impedance selector, the friend I built it for usually runs it at 8.
I did not add the accessory jack. My question is this: He would like to run two speakers simultaneously out of this amp, likely two at 8 ohms each. Would I just wire in the secondary jack as shown in the Fender/Hoffman schematics (looks like they are in parallel) and then switch impedance selector to 4 ohms when using two 8 ohm speakers?
Thanks!
« Last Edit: July 09, 2019, 01:04:43 pm by Diverted »
Re: Accessory jack Hoffman AB763
« Reply #1 on: July 09, 2019, 01:27:37 pm »
Yes, but one jack always short to ground in case no speaker is plugged in
If you have an impedance switch, you are good to go
Offline Diverted
« Reply #2 on: July 09, 2019, 07:21:46 pm »
Thanks EL34. Just wanted to be sure, didn't want to fry his expensive Heyboer output transformer.
Ted
Offline d95err
« Reply #3 on: July 10, 2019, 06:55:49 am »
A lot of old Fender amps had extension speaker jacks without any impedance switching. So apparently, a bit of impedance mismatch was not considered a problem.
I wouldn’t worry too much about it.
