August 29, 2026, 04:57:04 pm
Hoffman Amps Forum image Author Topic: 5e9a tremolo  (Read 4667 times)
Offline Leevi
    • Rikstone
5e9a tremolo
« on: July 11, 2019, 05:18:32 am »
What is the idea of the 10M resistor connected to the oscillation circuit?
At least the connection is causing 24v voltage on the foot pedal tip.
https://el34world.com/charts/Schematics/files/Fender/Fender_tremolux_5e9a.pdf
/Leevi
Offline d95err
Re: 5e9a tremolo
« Reply #1 on: July 11, 2019, 06:15:30 am »
I’m guessing it is to create a bit of a thump when activating the tremolo.
Oscillators sometimes need some kind of noise to get the oscillation started.
Offline Leevi
    • Rikstone
Re: 5e9a tremolo
« Reply #2 on: July 11, 2019, 06:55:15 am »
Yes, you are right, I tested it and it works like you mentioned.
Leevi
Re: 5e9a tremolo
« Reply #3 on: July 13, 2019, 05:14:50 pm »
Put your finger on it. Will come down to under a Volt. Quite safe, and normal for this plan.
As d95err says: An ideal oscillator may never start. (Simulations usually have to be tricked.)  Real oscillators do because there is always random noise, and because we set the idle gain to about 120% of the final gain needed to sustain oscillation. If we pencil 1V final and 1uV noise, we need about 76 passes through the amplifier to get that 1,000,000:1 rise of level. (1.2^76 is about a million.) Here we expect 10V or more final level, but in the sub-sonic band a tube's noise is high, maybe 10uV, maybe more.
In a 1MHz radio oscillator, 76 passes is less than an instant. At audio it is a part-second. But for say 10Hz tremolo, 76 passes is 7.6 seconds or several bars late.
With a perfect "kick-start" it is "possible" to get full level on the first half cycle with a minor glitch. But that needs critical adjustment, and isn't really needed. If you kick it pretty near full level, and it takes a few cycles to settle to final level, that's usually fine.
« Last Edit: July 13, 2019, 05:17:03 pm by PRR »
