August 29, 2026, 04:56:03 pm
Hoffman Amps Forum image Author Topic: Bumblebee confusion  (Read 4136 times)
Offline shaun
Bumblebee confusion
« on: July 12, 2019, 09:38:38 pm »
Hi, and sorry if this seems ridiculous, but I have this little 6AQ5 PP power amp with what looks like a bumblebee in it. But the only reading I can get off it is 0.503k, making it a resistor, not a cap. And the reading doesn't match the color code in any respect. Have I gone so nuts I don't know how to use my meter?
I've had no luck finding a schematic for the amp: Model Magnavox CR740AA. So far, none to be found.
Thanks for any help.
With gratitude.
Re: Bumblebee confusion
« Reply #1 on: July 12, 2019, 09:48:29 pm »
That's a cap and you probably have to remove it from the circuit to get a proper reading.
Does your meter have a capacitance setting?...some don't
It should be there to block DC so if it's doing it's job you can leave it alone.
« Reply #2 on: July 13, 2019, 01:21:41 am »
That cap is rated .1µF 20% 200V
Offline shaun
« Reply #3 on: July 13, 2019, 12:25:05 pm »
Thanks guys. Much appreciated. I do have a cap setting on my meter, but it wouldn't read it for some reason - probably as you say, I'd need to remove it from the circuit to get a reading.
With gratitude.
