September 14, 2026, 06:15:59 am
Hoffman Amps Forum image Author Topic: Hi Gain SE Amp  (Read 9436 times)
Hi Gain SE Amp
« on: July 22, 2019, 02:24:06 am »
Hi guys, On a bit of a hi gain kick at the moment.
Looking at these circuits for some hi gain blues rock.
After doing the 10w SLO clone and the trouble I had with the SLO preamp slamming the little output valves (some more tweaking has got it in a good place  :icon_biggrin:)
I'm hoping to reduce the output  by using the SE and maybe the EL84 will handle the ABUSE.
Re: Hi Gain SE Amp
« Reply #1 on: July 22, 2019, 09:14:47 am »
can't help but think that a switch to a grid with that much gain on tap isn't going to be anything but trouble. cap switching the cathodes like that is going to POP LOUD.  put a 47K-100K under each cap and use he switch to short across the resistor to enable. that's A LOT OF GAIN.
« Last Edit: July 22, 2019, 04:44:59 pm by DummyLoad »
Offline bmccowan
  • Better builder than player
Re: Hi Gain SE Amp
« Reply #2 on: July 22, 2019, 10:20:14 am »
I find this page an interesting discussion on SE- high gain amps:
http://chasingtone.com/dvnator/the-seplex/
I myself have not found SE EL84 amps to sound very pleasing, and the higher the gain, the more harsh they sound to my ears. I started playing around with them a few years back, following somewhat the Weber Smokin Joe 1 schematic. Finally ended up switching to a big bottle.  The best sounding SE amp I've built was a conversion of a SE Bogen CH8. 6AV6 - 6SJ7 - 6L6. I think there is a Jack Hester thread with a similar conversion of that Bogen. There may be some interesting thoughts in that thread.
« Last Edit: July 22, 2019, 10:48:57 am by bmccowan »
Mac
John Prine
Re: Hi Gain SE Amp
« Reply #3 on: July 25, 2019, 12:10:58 am »
here ya go. steel toe boots a must. hernia free a big +.
Re: Hi Gain SE Amp
« Reply #4 on: July 25, 2019, 04:16:47 am »
MAN, that is some beast....
Re: Hi Gain SE Amp
« Reply #5 on: August 10, 2019, 04:46:29 am »
Hi guys, Keen to hear this one, so shed got a workout today.
Re: Hi Gain SE Amp
« Reply #6 on: August 12, 2019, 08:21:03 pm »
A little progress...
Re: Hi Gain SE Amp
« Reply #7 on: August 12, 2019, 08:30:26 pm »
Coming together nicely.  :thumbsup:
Re: Hi Gain SE Amp
« Reply #8 on: August 13, 2019, 10:44:37 am »
Pete,
I expect to see your build progress on the Toe Crusher shortly?
Jim :icon_biggrin:
Re: Hi Gain SE Amp
« Reply #9 on: August 13, 2019, 06:57:29 pm »
Pete,
Jim :icon_biggrin:
mr. jimbob: sorry to say that i'm not much a fan of the soldano tone, so not building that. i did have a request to build a SP77 for an acquaintance and why i drew up the preamp plans - nothing materialized. i have other plans for the toe crusher/hernia discovery tool so stay tuned.
 :icon_biggrin:
Re: Hi Gain SE Amp
« Reply #10 on: August 20, 2019, 05:10:01 am »
Wiring complete......
Re: Hi Gain SE Amp
« Reply #11 on: March 01, 2020, 04:28:26 am »
Hi guys, Pushing on with this one.......
I've worked out a switching matrix, although I'm not sure this how it's meant to be, it works for me.
I'm wanting to use the heater power to supply the bridge rect as per the Hoffman site.
I have added two 100r resistors for the artificial CT even though the PT had a centre tap for the heaters ( the voltage either side of the CT were very uneven)
I had the heater CT connected to the cathode of the power valve to elevate the heater supply.
My question is....
Now that the heater supply is elevated is it OK to use the heater supply to power the bridge rect to power the relays.
Re: Hi Gain SE Amp
« Reply #12 on: March 01, 2020, 06:44:20 am »
did you set it up so the bridge and everything in the switching circuit was "isolated", NO ground to chassis on the DC side of the bridge or relays?  If so then it was already "floating".
the AC into the bridge doesn't "know" a DC reference or ground reference.  The DC - out off the bridge becomes "ground" for that circuit.  As long as that ground doesn't come into contact with real ground everything's happy as a clam
I think  :icon_biggrin:
Re: Hi Gain SE Amp
« Reply #13 on: March 01, 2020, 08:09:51 am »
Ciao TIMBO
OK, you are already on the route, however maybe you can find something of interesting here
http://el34world.com/Forum/index.php?topic=12774.msg119114#msg119114
On that thread there is (at post #4, by Sluckey) a link to a .pdf file that is out of service, here attached you can find the .pdf file
« Last Edit: March 01, 2020, 08:17:02 am by kagliostro »
Offline nandrewjackson
Re: Hi Gain SE Amp
« Reply #14 on: March 01, 2020, 08:31:35 am »
Shooter + 1
Your new "ground" at the bridge rectifier feeding off of the heaters IS NOT the same as your chassis ground,  so keep them separate.
Re: Hi Gain SE Amp
« Reply #15 on: March 07, 2020, 02:52:32 pm »
Hi guys, I'm getting some what PISSED off with the relays I've been using.
I built a little circuit board for the relays and all works as it should to a point.
I'll also add that the foot pedal will have two switches one for each relay.
Pretty simple....
But the drop in volume when RLY1 is activated (47k grounded)is very minor.
If I have RLY1 as it is on the schematic I can ground the 47k with a jumper and get the desired drop in volume.
So I'm rather convinced that the RELAYS that are being supplied these days are CRAP or I'm doing something wrong.
My next move is to remove the relays and wire the footswitches the same as the relays.
Re: Hi Gain SE Amp
« Reply #16 on: March 26, 2020, 04:22:16 am »
Hi guys, Moving this one along.....
Cab is mostly done..
Foot switch completed..
And replaced the EL84 with a 6V6GT
liking the 6V6 much better
Re: Hi Gain SE Amp
« Reply #17 on: March 26, 2020, 06:59:44 am »
WOW !!! that tolex is Fantastic TIMBO :thumbsup: :thumbsup: :thumbsup:
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
Re: Hi Gain SE Amp
« Reply #18 on: March 26, 2020, 11:04:28 am »
definitely that the 6V6 will sound better !
very neat job Timbo ! the two colours Tolex look awesome !
P.S.: call me Alvin.
Re: Hi Gain SE Amp
« Reply #19 on: March 26, 2020, 11:44:35 am »
Timbo,Your build quality has improved a lot! I'm thinking of the Beverly Hillbilly's opening song..."Black tweed, Texas tea..." Nicely done mate! Hurry up so we can hear what she sounds like!
