September 17, 2026, 09:41:35 am
Hoffman Amps Forum image Author Topic: Master volume options  (Read 5000 times)
Offline Swampertech
« on: July 23, 2019, 03:30:17 pm »
Hello All, I want to get your opinions as to the most transparent and usable linear Master Volume control circuit which would be installed after a LTP PI that drives a push/pull output stage (see attached). The circuit also has NFB with presence control, and I’ve read that there is some negative interaction with the post PI MV (Trainwreck Type-2/Lar-Mar Master Volume) and the feedback circuit. I’ve included the drawing with a pre PI single pot master volume. Thank you for your input!
Offline Swampertech
Re: Master volume options
« Reply #2 on: July 23, 2019, 06:25:31 pm »
Thanks Shooter! I did read those threads a while back.
Offline Big_Mike
« Reply #4 on: July 23, 2019, 08:01:39 pm »
As I understand it, with a PPIMV, the more you turn it down, the less negative feedback you get from the output transformer.  It can cause a different frequency response at low volumes.
There are a couple of design considerations you need to think about concerning whether to use a pre-phase inverter master or a PPIMV - 1) how important is the clipping and distortion you will get from the phase inverter? 2) how important is the negative feedback to the sound and feel of the amp, and 3) can you modify the preamp to get the gain and clipping you would otherwise get from overdriving the phase inverter, allowing you to use a pre-phase inverter master and keep the negative feedback?
Offline Swampertech
« Reply #5 on: July 23, 2019, 08:34:30 pm »
Big_Mike, thanks for the reply. My main concern is that the amp acts and sounds like it doesn't have a master volume. Assuming one would use the master volume at max setting most of the time, there should be no tonal coloration. When using either MV (pre or post), I'd like the tone to stay as close to the sound the amp has when the MV is maxed out, and that includes using NFB or no NFB.
